lb7 injector nozzels
Old Sep 20, 2010 | 05:11 PM
oleskied2005's Avatar
Default lb7 injector nozzels
i may have the opprtunity to buy a DMAX yeah i am a cummins guy but i might be able to get the lb7 for cheep it has leaking injectors and 149000 miles its on a maintenance schedual threw the company i work for its a bosses truck so hardly ever used what is the truck worth and if i do get it i was wonderin if i had to replace the whole injector or if i could just replace the nozzels if i have to do injectors what ones do u recomend i plan on doin aftermarket stage 1 there a lot cheeper then the factory bosch
my plans after the injectors were a 4-5" exaust and the edge juice any help would be great not that formilliar with the d max but after drivin it i have to say its not that bad of a motor pulled a 27' enclosed threw the mnts perfect
still love the 98 12valve for the truck pulls though.
Old Sep 20, 2010 | 08:12 PM
wildbill's Avatar
150,000ish miles, I'd replace the entire set of injectors. From what I've heard, they are a labor intensive project.
Old Sep 20, 2010 | 08:42 PM
mmasuperman12's Avatar
well the LB7 injectors suck to replace and there is a good chance youll have to replace the whole injector, there is a recalll for 7years 200K i dont know if it falls in that band it is getting awefully small now. the project is labor intensive but can be done if you have some mechanical skills.
Old Sep 21, 2010 | 12:05 AM
TruePerformanceDiesel's Avatar
FormerVendor
Defiantly look into the 7yr/200k mile warranty and replace the whole thing is a must,
Old Sep 21, 2010 | 09:38 AM
K50's Avatar
K50
Replace all 8 injectors. That warranty has probably expired by now unless you had a late model '03. 6.5hrs/engine bank, 13hrs labour-> $1800 in parts, $3200 in labour ~$5000 for the job from most diesel shops unless you're able to do it.
Old Sep 21, 2010 | 08:11 PM
there is a great write up on here on how to replace them, definitly helpful if you are going to try it yourself, like said above if you cant do it, it will cost you...alot
https://www.dieselbombers.com/lb7-bo...ips-hints.html
here ya go, have a read and see if you think you can do it, very beneficial!
Last edited by mmasuperman12; Sep 21, 2010 at 08:11 PM. Reason: Automerged Doublepost
Old Sep 21, 2010 | 08:46 PM
its not an issue for me to do the change myself very mecanical planed on doin it myself herd it was a some what a long task not an issue i got a shop to do it in
any addvise in injectors should i go stock or stage 1 aftermarket big price diffrence just wonderin
Old Sep 22, 2010 | 12:10 AM
Red_Rattler's Avatar
High Tech Redneck
My bud is making 600hp easy on stock injectors... Lil food for thought
Old Sep 30, 2010 | 11:28 AM
bftrain's Avatar
Replacing the tips will do nothing for the injector as it is the ball and seat in the body that wear out. If you are there replace all eight. Unless you plan on getting a bigger/dual CP3's use the stock injectors.
Old Oct 3, 2010 | 02:53 PM
2500HeavyDuty's Avatar
mlknutzen
Chevy/GMC Duramax 01-04 LB7
Oct 1, 2015 10:56 AM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
dshopex4
14
Apr 15, 2015 09:40 PM
Adam Sanders
LB7 Performance
Jan 21, 2015 06:57 AM
Trevlar11
Dec 21, 2014 03:16 PM
