Motor Swap
Old Oct 25, 2007 | 08:26 PM
dhgreen's Avatar
Question Motor Swap
Hey everyone my names dan. i dont own a diesel yet but i am wanting to swap my engine for a 12v cummins. my question for everyone is that my truck is a 2001 chevy HD reg cab longbed 4x4, its got the vortec 8100 (496ci)gas motor with a 6 speed manual, what i need to know is if the bell housing for a dodge 6 speed will bolt up to my tranny i know the 5 speeds are interchangable but havent heard of anybody performing the motor swap with a six speed cause i would like to keep my tranny. So any help would be appreciated.
thanks dhgreen
Old Oct 25, 2007 | 08:48 PM
Welcome dhgreen ...moving this for better exposure.
Most of the Cummins guys probably arent real familiar with GM trannys...what is it?
Old Oct 25, 2007 | 11:52 PM
DBogo's Avatar
it should be a ZF6 if im correct, if thats the case, ford uses the same tranny in there trucks so the ford adapter should work fine, you would just need probably a different starter, possibly a ford one, as for the motor fitting it should be fine, check out this place
www.destroked.com
Old Oct 30, 2007 | 01:15 PM
dhgreen's Avatar
hey thanks guys for the help and info.
Old Oct 30, 2007 | 05:53 PM
DazedandConfused's Avatar
If the ZF6 is the same as the old GM bolt pattern on the bellhousing you can get the plate to mate a Gm trans to a Cummins through Cummins. The old Bread trucks ran Cummins with 400turbo's behind them.
