97 7.3L F250 waste gate
Old Sep 18, 2010 | 09:40 PM
aboyle55's Avatar
Default 97 7.3L F250 waste gate
My waste gate is failing. What does it do? My mechanic showed me mine during the rev cycle and it wasn't moving.
Old Sep 19, 2010 | 08:58 AM
PHPDiesel's Avatar
Sponsor
Your 97 has a wastegate? I think we need a little bit more information as far as what your truck is doing or what symptoms lead you to believe that your wastegate has failed (especially since your 97 does not have a wastegate unless it's undergone some major modifications).
What exactly did your "mechanic" show you when he was talking about a wastegate?
Old Sep 19, 2010 | 11:44 AM
cummins bronco's Avatar
i think you need a new mechanic, i he was probabaly showing you your back pressure valve, which only closes for warm up.
Old Sep 19, 2010 | 09:32 PM
aboyle55's Avatar
He said the waste gate was attached to the underside of the turbo. Is that the back pressure valve?
Old Sep 20, 2010 | 12:08 PM
yup sure sounds like it.
Old Sep 21, 2010 | 10:12 PM
aboyle55's Avatar
I asked the mechanic about the waste gate. He said it's just a general term and Ford doesn't call it a waste gate. He said it is a back pressure valve.
Old Sep 21, 2010 | 11:40 PM
CSIPSD's Avatar
... No, its not a general term. I would find a new Mech.
Its an exhaust back pressure valve, and the only time it should move is when the PCM orders it to, which is on cold start up only... Unless he was running a KOER test, then he has no way to "tell" you its not working.
Old Sep 22, 2010 | 02:15 AM
your mechanic sucks, get some one who knows what they are talking about.
a wastegate and a backpressure valve are not even similar.
six speed
Sep 14, 2015 09:19 PM
asajay
Sep 10, 2015 12:08 AM
timmyd
Jun 8, 2015 11:35 PM
SammyB
8
Apr 21, 2015 10:37 AM
Rvasak
Oct 29, 2014 01:21 AM
