24v cummins need some advice
Old Sep 13, 2010 | 07:06 PM
aaronmoore's Avatar
Default 24v cummins need some advice
i got 3 codes this morning on my truck sometimes it will run good and then sometimes it wont. first code is p0523 oil pressure sending unit voltage too high.and p1689 no communication between ecm and inj pump module.and last p1693 generic fault indicating a fault in the bus or pcm/ecm interface any ideas how to fix i already checked grounds and connection goin to pump thanks aaron
Old Sep 13, 2010 | 08:05 PM
cummin_un_glued's Avatar
FormerVendor
that dosnt sound good, the last couple trucks i've seen with the 1689 code have ended up being bad injection pumps...only thing that i can think for you to do is check the voltage on pin 7 i think it is coming out of the harness when it plugs to the pump, if i remember right its susposed to have atleast 8v on it....maybe someone else will chime in that knows for sure
Old Sep 13, 2010 | 08:26 PM
aaronmoore's Avatar
ok I already checked it and it showed 2.56v and I read up on internet to go by a p0215dtc circuit check. Thanks Aaron
Old Sep 13, 2010 | 08:35 PM
Lil Red Express's Avatar
Yap your inj pump gave up.
Old Sep 13, 2010 | 08:54 PM
aaronmoore's Avatar
When checking voltage on that wire on injection pump plug put the red wire off meter on the red and light green wire and the black on ground?? Right
Old Sep 14, 2010 | 06:49 AM
FormerVendor
i've neved looked at the color of the wire i allways just stick the voltmeter prob into the plug on the end of the harness and yes ground the other side....with the key on
Old Sep 14, 2010 | 12:19 PM
aaronmoore's Avatar
well its got 12.49 volts so i assume my pumps bad cause everyone already told me p1689 usually means bad pump and ive already put a new lift pump on about 3 months ago.
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
gh0stman
Price Quote - Request A Price
Sep 9, 2015 12:12 PM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
Downd19
Dec 30, 2014 02:49 PM
