straight axle conversion please!
fter owning this 96 f250 for about a year im already hating the TTB system. does anyone have a step by step from what to buy to installation. much appreciated
The F250 front TTB axles are leaf sprung correct? If so it should be an easy swap because the suspension is pretty much there. you would have to remove the center mounting brackets for the TTB arms and bolt a solid front axle in its place from with it looks like. the factory steering box should work fine but you would have to get a steering dragling to mount from you pitman arm to the steering knuckle but I am sure you could probably use a front axle and steering from a newer model solid axle 250 or 350 as long as it was a leaf sprung front.
ive got a 96 f350 dually and its a 2wd wich i hate but its a custom truck so i want to convert it to 4wd alot of people said the frame should be pre drilled to take a 4wd front end but will the front shat fit past the oil pan and what other mods besides steering and tranny will i have to make....any help?
take out the old and swap in the new.
i did mine in about 2 hours by my self taking my time.
so my frame should be made to bolt up a 4wd front end right? i was told it would and i really hope it does...what about clearance under the engine and front end for the new tranny and drive shaft? will it fit without mods?
My truck is a 96 f250, the previous owner really tweaked that shitty TTB. My Dana 60 came from a 92 f350 and everything was direct boltup except brakehoses, U bolt issues and cutting the bolts that hold the TTB off of the crossmember. well worth your time!
Dec 19, 2014 02:30 PM
