Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Can I Do Without A Tow Module?
Old Oct 23, 2007 | 05:26 PM
GRI's Avatar
GRI
Default Can I Do Without A Tow Module?
I'm possible picking up a jeep cheroke sport that I'll have to tow on a car trailer. do I need a brake module? I'll be traveling 700 miles round trip.
thx
Old Oct 23, 2007 | 05:46 PM
DazedandConfused's Avatar
No not if you use common sense. Be cautious and keep your distance. Dont speed and all that good stuff.
Old Oct 23, 2007 | 05:51 PM
Shelby322's Avatar
If there is a lot of hills I would suggest buying a cheap module. You can probably pick one up for $60-80 and easy enough to install and save some wear and tear on the truck. If you are hard on the brakes while towing, warped rotors are not to cheap replace - Use common sense and you will make the right decision
Scott
Old Oct 23, 2007 | 06:01 PM
2001shrtbedcummins's Avatar
here's one that ain't to much...http://cgi.ebay.com/ebaymotors/Tekon...ayphotohosting
Old Oct 23, 2007 | 06:06 PM
GRI's Avatar
GRI
yeah thats the module I would get because I have the harness that will hook right up to my truck without splicing.
Old Oct 23, 2007 | 06:50 PM
MRaynor's Avatar
As was said, I would just use common sense and make sure you keep your distance. I'm sure that you will be fine.
Old Oct 23, 2007 | 07:27 PM
Uncle Bubba's Avatar
No problem at all. Trailer brakes are good for safety sake on loads of that weight, but your truck is heavy enough to stop it easy, your talkin less then 8000 pounds. I haul that all the time without even hookin up the trailer wires and don't have any problems stoppin.
Old Oct 23, 2007 | 07:30 PM
Benjamin's Avatar
Bombardier
a brake contrller is always nice to have.... nessary pulling an average size car? prolly not like stated above..... just make sure before you get one that your trailer has brakes on it....
Old Nov 23, 2007 | 06:53 AM
snowball's Avatar
I can't believe you guys would condone or even advise someone to pull a load that size without brakes. Pretty sure anything over 4000 lbs is required to have brakes. Wow!
Old Nov 23, 2007 | 10:24 AM
2141pete's Avatar
I went 1100 miles with a ranger on a car trailer LOADED down with all our crap twice. I had no problems but I didnt speed and kept alot of dispersion with the other cars on the road.
