A few turbo questions
Old Sep 9, 2010 | 10:47 PM
Cumminsdieselboy's Avatar
Default A few turbo questions
ok here is my dilemma. on my 97 i have coaltrain 5x14's, scheid LCDV's, 4kgsk, hi-rise injection lines, 18.5-19* timing and a super phat shaft 66 turbo. at WOT i can get around 1800-1900* exhaust temps from her while making 55psi of boost. the truck dont clear up, and at night i can make flames come out of dual 9" diameter stacks NOT GOOD
I have a brand new HT-60 with a 22cm housing. i am not too concerned with spoolup (im use to the 66), but didnt know if doing that would help my egt's. I noticed on CDS's website they have stock dodge manifold to HT-60 flange adaptors...
I would love to put an HX-35 on top and use the 60 as a bottom but money is tight so i cant do that.
Any insight would be appreciated
Thanks
Cody
Old Sep 10, 2010 | 09:41 AM
94 12valve's Avatar
you could get rid of the lazer cuts, keep your 66, and have lower egt's
Old Sep 10, 2010 | 08:13 PM
But i like having the fastest diesel in this area, and i dont want to lose any power. i only have a 180 pump and i don't want to go back to stock dvs in case they dont like my 140's.
i know the ht-60 is too small to go under the 66, so id have to use a stocker for the top correct?
Old Sep 11, 2010 | 06:04 AM
94 12valve's Avatar
215 or 180 ppump?
Old Sep 11, 2010 | 07:32 PM
12valvetater's Avatar
Only a 180 pump? Fella, that is the pump to have. Give it more timing. Take it up to 24ish and see how it acts.
Old Sep 11, 2010 | 08:11 PM
yea only a 180 pump. motor was swapped supposedly.
about the timing...im running torqued over head bolts on a .020"+ headgasket running 55psi of boost. i didnt know if it would raise cylinder pressures too high and blow a headgasket.
thanks so far guys
Cody
Old Sep 11, 2010 | 08:36 PM
monster12valve's Avatar
yea 24* will not be good for the head gasket..
Old Sep 11, 2010 | 08:47 PM
thats y i stopped at 19*.
How much do u guys honestly think it would cost for piping from an hx35 to an ht-60 would cost. i saw somebody made a kit i just cant find who.
Old Sep 11, 2010 | 09:05 PM
kyle davis's Avatar
i just made a kit for my truck and had probably around 300$ in the piping and stuff but i have a super b and ht60
Old Sep 11, 2010 | 09:08 PM
ok cool. that may work. would my 66 be too big for atop the ht-60?
