No Power!!!! Running On Four Cylinders
Old Oct 22, 2007 | 05:54 PM
Diesel-N-Dust's Avatar
Default No Power!!!! Running On Four Cylinders
My truck fell flat on its face today, I "Limped" home and retrieved these codes with my predator,
Po202 Injector circuit malfunction cylinder #2
Po203 " " " " #3
Po205 " " " " #5
Po208 " " " " #8
Po522
P2149
nd064
Is this something I can fix myself, Or should I take it to the dealer?
Thanks in advance,
John
Old Oct 22, 2007 | 05:59 PM
DB Admin's Avatar
Banned
They all seem to be circuits/sensors Low Voltage ect
Did you jump some one recently or weld on the truck ?
Maybe ECM/PCM Malfunction
Reset codes and disconnect batteries for a hour then reconnect and start it up and see if it throws codes
DM
Old Oct 22, 2007 | 06:04 PM
Benjamin's Avatar
Bombardier
p0522 is power steering pressure sensor circuit low input
p2149 injector positive voltage control circuit group 2 (GM)
sounds perty drastic to me..... what year is the truck? is it under warranty?
Old Oct 22, 2007 | 06:05 PM
LOGANSTANFORTH's Avatar
there are 2 wiring harnesses, one going to each bank of cylinders, check them for fraying, cuts or abrasions, typical duramax problem.
Old Oct 22, 2007 | 06:09 PM
Thanks guys, I did a search on another forum, Aparrently there is a problem with the wiring harness on these trucks. I will take it to the dealer tomorrow.
Old Oct 22, 2007 | 06:13 PM
DangerousDuramax's Avatar
John, I will call you in a few minutes. I've been teaching a class and just got done thats why I couldnt answer the phone. There are far more than two harnesses on the DMax for each bank. I'll call in a minute and help you through it.
Old Oct 22, 2007 | 07:00 PM
Thanks Tracy!
Old Oct 22, 2007 | 07:09 PM
John, something else I thought of...go through 10 key cycles and see what codes clear.
Old Oct 22, 2007 | 07:10 PM
Thats only on the #2 and #7 injector harness. You can fix the #2 harness easily on the side of the road in about 10 minutes. The #7 is a to get to.
Old Oct 25, 2007 | 11:20 PM
Benjamin's Avatar
Bombardier
did ya'll get this figured out? what was the fix?
