rack plug
Old Sep 3, 2010 | 09:00 PM
diesel_dude379's Avatar
Default rack plug
where could i find the big rack plug??????
Old Sep 3, 2010 | 10:31 PM
wes-cummins's Avatar
go to a mack dealer and ask them for a 2095 rack plug for a p7100
or search the internet
Old Sep 4, 2010 | 01:53 AM
captain_stabbin's Avatar
pure diesel power sells them
Old Sep 4, 2010 | 11:10 PM
12vcummins96's Avatar
use one our vendors do a price request
Old Sep 4, 2010 | 11:13 PM
tiremann9669's Avatar
What is a rack plug and what does it do ?
Old Sep 5, 2010 | 12:13 AM
oglejust's Avatar
its the plug on the front of the p pump. its what limits rack travel. the 2095 rack plug provides more rack travel but to install it u either grind the timing case or slide the pump back.
Old Sep 5, 2010 | 08:09 AM
94 12valve's Avatar
max rack travel with the stock plug 19mm
max rack travel with the mack plug 21mm
For the plug to allow the extra 2mm of rack your afc and plate set up will have to allow it.
Old Sep 6, 2010 | 09:18 PM
cumminspwr11's Avatar
is that stock rack travel of 19mm on the 160 pump or all the other ones? i put the 2095 plug on my 95 and mod. the afc housing so that the foot got max travel and it made a pretty good difference, i believe you also either have to have the plate ff or no plate to use that much rack travel
oh and on the 160 pumps i heard it allows the pump to change timing as you go thru the rpms, where as the 215 pump already does this. is there any truth to this or did i miss understand something?
Last edited by cumminspwr11; Sep 6, 2010 at 09:18 PM. Reason: Automerged Doublepost
Old Sep 6, 2010 | 09:21 PM
94 12valve's Avatar
never heard that about the 160's but as far as 19mm being max rack on all the pumps with the stock plug that is right
Old Sep 6, 2010 | 10:48 PM
Red_Rattler's Avatar
High Tech Redneck
Tried that... Didn't get any help. Mack dealer if you have one near you
