10 speed??
Old Sep 1, 2010 | 03:37 AM
latenighthaulers's Avatar
Question 10 speed??
just saw a video on youtube a guy stuck a fuller 10 speed in a 1ton behind a cummins???? i want to do it now! thought about it a long time ago and didnt figure it would work but i guess i was wrong.......now anyone got any ideas???? trust me im all ears!!!!!
Old Sep 1, 2010 | 03:46 AM
duramaxfarmboy's Avatar
first things first your going to have to figure out the difference in bolt patterns ur cummins is and find a tranny that is close im sure you can get an adapter made to fit it. the next thing would be figuring out what clutch would work. that and ur going to need to know what size input shaft is on the transmission. then ur either going to have to get the yoke from the out put shaft change or get a new drive shaft made to fit the different sized u joint and not to mention an air system for the splitter
Old Sep 1, 2010 | 07:16 AM
ForcedInduction's Avatar
Then you'll also notice how frequently he shifts. A 10-speed is pointless.
Old Sep 1, 2010 | 12:01 PM
that may be true but i own 4 trucks and hot shot coast to coast try hitting grapevine a 40k it would help a lot to have more gears. thats the reason you dont see many 10 speeds on the west coast the run 18 and 13 speeds power to weight ratio for one but have a gear that will only drop your rpms by 2 or 3 hundred to gain from helps a lot. i used to drive 18 wheeler and a simple change from 10-13 or 13 to an 18 helps a lot
Old Sep 1, 2010 | 01:10 PM
Chaddilac's Avatar
do what makes you happy bro i love rowing gears
Old Sep 1, 2010 | 02:16 PM
C16 power's Avatar
That trans weighs more than a 6bt, unless he swapped bell housings I can't imagine it fitting well between the frame rails of a 1 ton.
Old Sep 1, 2010 | 02:40 PM
Chaddilac's Avatar
Default here ya go this guy sells adapters
Roadranger 10 Speed Conversion...it Can Be Done!!! - Dodge Cummins Diesel Forum
Old Sep 1, 2010 | 05:10 PM
C16 power's Avatar
NEver said it couldn't be done but it's alot of work. That's a medium duty trans too, I've had a RTLO18718B 18 speed (basically same case as 9 speed with the back half different for splitter) on a 1 ton dualie bed and it was saggin. I was toying with the idea of putting a RTO1409A behind my cummins. The 6bt is used in spotter yard trucks that have air brakes so be easy to just mount an air compressor from one as long as front cover is same (which I think it is) then mount vacum pump with ps behind compressor for air. Then you're talking 1200-1400lbs of extra weight. But having a twin counter shaft non synchro trans and floating gears in a pick up would be the cats meow! The more I think about it the more I wanna do it as the eaton would take anything the 6bt could throw at it without breaking a sweat! And we do alot of hauling with it, up to 26k lbs where the dodge a518 has trouble.
Nice thing bout the 1409A is it's a double OD trans, last gear in trans is flipped around making it a tall last gear. It also is a U shift pattern not an H pattern.
Old Sep 1, 2010 | 11:40 PM
Old Sep 2, 2010 | 01:47 AM
FTE's Avatar
FTE
A Browny aux trans behind a 5spd will get you there as well, and will fit easyer. I did that to a F600 years back and made a POS into a hauling beast! It was way more fun shifting the twin sticks too!
