Help with wiring, 12v into ford please!
Old Aug 21, 2010 | 07:18 PM
C16 power's Avatar
Default Help with wiring, 12v into ford please!
I just hate it and im usually clueless when doing this, i got a couple questions, 92 rotary pump and ignition.... Do i use the ford starter solenoid or wire into the dodge starter, also i know its simple but which wire do i need to splice into at the pump, i see theres 2 wires and 1 at the fuel shut off solenoid. As i said i hate wiring, im a fabricator and never did this before, pics usually help me as i need to see, kind of need to get this truck running today and thats all theres left to do.
Old Aug 23, 2010 | 09:03 PM
92_cummins_f250's Avatar
The VE doesn't have a "shut off" wire like the P-Pumps do, they only require a "12V hot" to run. The upper spot that has two blades/wires coming off of it is the 12V run, just run your 12V "key on" hot wire to it. The second wire coming off of it is a jumper to or from something, I want to say a sensor of somesort but can't remember for sure now. The lower wire is the KSB cold start solenoid, which I set up on a toggle switch.
Old Aug 23, 2010 | 09:23 PM
C16 power's Avatar
Yeah I see that now, I appreciate it! Think I got it figured out, hope to have it running this weekend.
Old Aug 23, 2010 | 10:06 PM
Are you leaving the factory Ford computer in the truck?
Old Aug 24, 2010 | 01:12 AM
C16 power's Avatar
Yeah I think so.
Old Aug 24, 2010 | 08:15 AM
Ok, I never tried it without, but the wiring for the VSS goes through the computer so I don't think the factory speedo will work without leaving the computer in the truck.
Old Aug 25, 2010 | 03:11 AM
C16 power's Avatar
THat's what I heard too so I decided to leave it.
atreefunk
For Sale
Apr 13, 2015 10:57 PM
Nov 4, 2014 01:30 PM
Oct 14, 2014 10:10 AM
Oct 14, 2014 08:40 AM
