P0089 Fuel Pressure Regulator Performance
Old Aug 20, 2010 | 09:17 PM
ironworker's Avatar
Shut Mouth P0089 Fuel Pressure Regulator Performance
I have had my truck less than a week and it throws a code to day P0089 Fuel Pressure Regulator Performance can any one tell me any thing about it ? i cleared it and 30 mi or so it threw it for a second time
Old Aug 31, 2010 | 11:32 PM
oglejust's Avatar
Circuit Description
The engine control module (ECM) uses commanded fuel pump flow to determine a desired fuel rail pressure (FRP). The actual fuel pressure is monitored using the FRP sensor. If the FRP sensor indicates a pressure more than 20 MPa greater than desired, DTC P0089 will set.
Conditions for Running the DTC
• DTCs P0192, P0193, or P0641 are not set.
• The ignition is ON.
Conditions for Setting the DTC
• The difference between actual and desired FRP is more than 20 MPa.
• Commanded fuel pump flow is 100 mm³/second or less.
basically u have 4 choices
1. wiring
2. ecm
3.fuel rail pressure sensor
4.fuel pressure regulator
Old Sep 1, 2010 | 08:57 AM
ironworker's Avatar
I have been running Lucas Fuel treatment in it for the last couple tanks and i cleared the code after the first tank because the the motor surge that had started to show up when slowing down ,befor the fuel treatment, had went away. Knock on wood it has stayed off.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
