Pro Comp Eextreme All Terrain Pressures?
Old Oct 17, 2007 | 11:20 PM
dieseljunkie's Avatar
Default Pro Comp Eextreme All Terrain Pressures?
Ok guys, I have a set of 35x12.50x17 load range D on the truck, and I am trying to see what others with this tire are running for tire pressure. I have them set at about 50 psi right now front and rear, and they LOOK to be wearing ok, but I am not 100% sure on how they are wearing. I just wanted to get a feel for what others are running with the same tire before I do the chalk test.
Scott
Old Oct 18, 2007 | 08:42 AM
Johnny Cetane's Avatar
get a grease pencil or piece of chalk. draw a line across the face of each tire and then drive a couple of feet and see where the line is worn off on the tire. adjust pressure from there.
Old Oct 18, 2007 | 02:36 PM
Sharx Ram's Avatar
Het Scott, Iam running the ProComp Extreme A/T Load range "E" I believe I am running 32 LBS but I will check when I get home to make sure, They have been wearing great, I have no complaints.
Old Oct 19, 2007 | 05:21 PM
Cool deal. I will have to pick up some chalk or grease pencil tomorrow... Sharx, any input from you would be great. I am very happy with these tires, but I gotta say I have only had them on for a week, and about 300 miles, and they are already looking like I should have just gone to 37's "
Scott
FYI... for anyone with these same tires... I did the chalk test on the tires today, and I settled on 40psi front and rear.. Seems that will give me the best wear....
Scott
Last edited by dieseljunkie; Oct 19, 2007 at 05:21 PM. Reason: Automerged Doublepost
Old Mar 24, 2010 | 12:13 PM
92 cummins's Avatar
I have my extreme A/T at right about 45psi, i've gotten real good wear from em'
Oct 23, 2014 11:00 AM
