lb7 injectors
Old Aug 15, 2010 | 08:37 PM
bruno8's Avatar
Default lb7 injectors
Replacing the head gaskets and noticed inj lines look corroded where they screw onto the inj,also when I removed the line all the corrosion crap fell into the top of the inj fitting-wondering if i should send them out to be ckd-should I just clean the lines or replace them - 3 or 4 of them were like that the rest looked ok
Old Aug 16, 2010 | 08:55 AM
TimAT's Avatar
There's a note here:
https://www.dieselbombers.com/chevy-...r-service.html
All about cleaning the corrosion on the fuel lines.
Old Aug 16, 2010 | 11:47 PM
bruno8's Avatar
Thanks -good info -wish I had it before I took lines off-I turned inj. upside down -dumped out debris-gave a spray of brake clean why it was upside down hope its ok
Old Aug 19, 2010 | 03:08 PM
2500HeavyDuty's Avatar
you can use some solvent to clean the injectors out, its normally closed so all the gunk can be flushed out
Sep 7, 2015 07:30 AM
klein444
Mar 8, 2015 11:42 AM
angelic0-
Price Quote - Request A Price
Dec 7, 2014 02:03 PM
damanrescue
Dec 2, 2014 04:12 PM
Back-in-Black
Nov 29, 2014 12:40 AM
