Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
dana 60 ????s
Old Aug 6, 2010 | 03:16 PM
cumminspwr11's Avatar
Default dana 60 ????s
what year did dodge use a dana 60 front axle with NO CAD system and 32 spline shafts? my dads 02 has a dana 60 under the front end and someone welded all the mounts and brackets to it and it looks really good but the bearings went out in it and it made the truck undrivable until we pulled the axle shafts out, it has 32spline shafts and a locker or something because the pinion bearing went out and froze the pinion and ring up and it would let the front tires spin at all, which shouldnt happen if it was an open diff right?
Old Aug 6, 2010 | 03:49 PM
94cummins12v's Avatar
coreect if it were an open diff the tires would still spin if the pinion didnt
Old Aug 6, 2010 | 05:53 PM
doesnt it make it a pain the *** to steer with front end locked together even if your not using 4x4?
Old Aug 6, 2010 | 05:57 PM
yes imagine in a normal truck with the hubs still locked but no pwer to the front end when you turn it still hops same in your case
Old Aug 6, 2010 | 06:01 PM
thats what i thought
Old Aug 7, 2010 | 01:20 PM
kazairl's Avatar
Mid year 02 is when they started using the noncad axles. My 02 is noncad also.
Old Aug 12, 2010 | 09:56 AM
hum that makes sence and did they switch over to the 32spline shafts also?-kazairl
Old Aug 12, 2010 | 03:58 PM
kazairl's Avatar
I believe so. I had my axles pulled out not that long ago but I never checked to see how many splines it had. Most info I have read indicates they switched to the 32 spline at the same time.
Old Aug 16, 2010 | 12:32 PM
cool, thanks for the info, i counted the splines and it is a 32 spline shaft, and the other two axles i have pulled apart from older dodges have 30 spline shafts
woodsman27
May 23, 2015 10:16 AM
tractormandan
Wanted To Buy (WTB) - Used
May 9, 2015 08:44 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
KYLEBOY
Jan 18, 2015 06:36 PM
gyayo2012
Nov 15, 2014 08:11 PM
