white smoke cankcase pressure
Old Jul 31, 2010 | 05:33 PM
duke 2000's Avatar
Default white smoke cankcase pressure
hey i have put all new injectors and glow plugs in my 1987 6.9. prior to this it was runnin really rough and back fired hard enough to break windows. now iam gettin white smoke and crankcase pressure that knocks my oil pressure to zero. the motor has 310 thousand milea on it. headgasket or what?
Old Jul 31, 2010 | 08:55 PM
DieselCrawler's Avatar
how many miles are on the pump?
also how would the cc presure knock oil pressure to zero?
also when was last time pump was timed?
Old Jul 31, 2010 | 09:46 PM
Robby Avery's Avatar
White smoke is raw fuel but it can also be engine coolant burning for instance HG's blown or dribbling injectors could be injecting alot of fuel. Blue smoke would be oil but you said white just giving some more info.
Old Jul 31, 2010 | 10:20 PM
poocher pup's Avatar
at idle, at speed, at startup, when?
Old Aug 1, 2010 | 01:16 AM
duke 2000's Avatar
hey its only blowin white smoke when i rev motor !
Old Aug 1, 2010 | 09:37 AM
still didnt answer my questions.
Old Aug 1, 2010 | 10:01 AM
duke 2000's Avatar
there is about 50000 miles on pump ! i figured out oil problem crap in sendin unit ! pump was timed when put in !
Old Aug 1, 2010 | 04:20 PM
this white smoke, does it smell of coolant? or just fuel?
Old Aug 1, 2010 | 07:47 PM
X2!!!!!
Old Aug 4, 2010 | 09:28 PM
duke 2000's Avatar
ok ! white smoke fixed ! bad injector ! Now i got oil running out tail pipe and oil pressure is low and drops off to nothin ! only blows gray smoke at higher rpm.
