DT466 Pulling truck Build
Old Jul 30, 2010 | 02:53 AM
Bosshawg600's Avatar
Default DT466 Pulling truck Build
Ok, so I didnt know were to put this, I thought Sled Pulling Forum, but it would just get lost in the general babble.......
Anyways, I bought a 93 Dodge Ext Cab DRW to build into a puller. I got the 1st gen just due to the fact that you dont see too many out there.
Well, Ive had some downtime on it lately doing some other things and trying to find a good frame and drivetrain to start with. Anyways, this downtime has given me a ton of thinking time!!! So I got to thinking....to make my truck even more differnt...Im throwing around the idea of throwing a DT466 in the 1st gen and go pulling for fun!!!
As Ive been looking for info (and I have read just about everything I can find!!) there realy isnt that much out there to turn up the wick on a DT466!!!! Im going beyond the avrage free pump upgrades and such and there isnt much more than that.
Now this is strictly a puller for fun, just go out and run the Run What Ya Brung and open classes around the area, and if I get enough meat between my legs, take it to a big show and pull there (Yes I know, Mod Class and Ill get killed...whatever!) but I think it would be cool to see and build! I got a buddy with a decent 3.0 truck that does the same thing, so I guess we can go around together and put on a pretty good show!
My goals are not that lofty just due to the fact my wallett isnt that thick! So Im thinking about the 600-700HP range should make it run down the track pretty good! But how do I get there? Can I use 12v parts that might interchange? Im looking for a 94-97 DT466 so it will have a P pump that Im pretty familiar with, so i hope to turn that up myself.
I dont think I have the coin to go with Hypermax stuff just due to their prices!!! I mean &k for an overborekit??? Ain t gonna happen!!!
All in all, I think If can get 700hp at 4500RPM going down the track....thats a VERY good start!!!
Any help I can get from you guys would be AWESOME......and Better than everywere else Ive tried!!!
Old Jul 30, 2010 | 08:01 AM
powerstroke cowboy's Avatar
The DT466 in the years 94-97 are not P-Pumped. They have the same Kind of injectors as a 7.3L Powerstroke, they just flow a lot more. They have HEUI Injectors. Go with a older DT466 that is macanical. A DT466 In a firt gen Would be sweet I would like to do the same thing in a 78 to 79 Ford F-350. O and the DT466 are easy to turn up to 1000+ HP. And you can do it cheaper then a 700 HP 5.9L. Just keep us posted on the Build. And have FUN.
Old Jul 30, 2010 | 09:25 AM
kmkdiesel's Avatar
most people throw on a p7100 215 pump because they are proven pumps alot easier to adjust and are not as finicky trying to tune, there are 3-4 dt466 pullers here, they all run pretty good but the cummins still beat them in supermod class.
Old Jul 30, 2010 | 09:58 AM
cumminspwrram59's Avatar
if you really wanna be different go with a 8.3 cummins they are mostly found in the ford 8000 series trucks if i remember right they are p-pumped too
Old Jul 30, 2010 | 01:05 PM
J-Pipes's Avatar
If you are set on the DT, try looking for info on pulling tractors. They used the same DT series for alot of years in tractors, just with varrying displacements. I know one local shop that is into the tractor pulling as well as the trucks has 525ci kits for the DT engines. If you want to talk to the guy let me know and I will PM his number, and website. But I still think an 8.3 Cummins would be sweet, I believe it is a member of the B series engine family, so it should be just like working on a 5.9, only bigger
Old Jul 30, 2010 | 04:53 PM
93_Fummins's Avatar
8.3 is a 6CT...C-series family
Keep in mind that there are at least 3 DT466 configurations, much like the B series Cummins; a rotary pump model, a P-pump model and the HEUI injection model. The tractor pullers love the P-pump model, and there is MUCH power to be had from them. I know a few guys that pull 1466 IH tractors with highly modified DT466 mills pushing well over 1000 horsepower. Definitely buddy up with some tractor pullers and look for hand-me-down injectors maybe... Then get some big 'ol turbos and a high pressure water injection system and see what you can pull off!
Last edited by 93_Fummins; Jul 30, 2010 at 04:53 PM. Reason: Automerged Doublepost
Old Jul 31, 2010 | 07:02 AM
Im not dead set on a DT....just due the fact that I dont know how Im going to do it. I know i want to go with a P-pump style DT and I can get some decent power out of it.
But my biggest problem with going DT466 is that I have no idea on a trans/t-case set up. Im not too good with the Med and heavy truck trans. stuff so i dont know if I want to go that route. if I can find an adaptor to hook the DT up to an NV4500 Id be set!! But i dont even know if that possible.
I guess I could go with a Fuller or something in that range, but that leaves out a T-case........Its all just a crap shoot.....Then I got to think clutch!!!!!
Im building this just for a fun puller, so i dont care about what class i fit into...Heck the classes around here are just way to crazy now anyways and I dont have the pockets to even break into the top 10!!!
I think it will just be fun to go out, have something cool and differnt, and have fun!!
But if I can just get some big details solved...I think it can be done!
Old Jul 31, 2010 | 09:30 AM
J-Pipes's Avatar
Maybe an SCS reverser box? I think that it actually functions as both the trans and the t-case, I think.
Old Jul 31, 2010 | 03:19 PM
You got 3 grand you want to donate for just the box? If I buy a drop box and reverser, Ill build a 3.0 truck....which I auctually would like to!
Old Jul 31, 2010 | 05:33 PM
93_Fummins's Avatar
Source a 2-ton divorced t-case from a Deuce or something big, then you'll have big u-joints and everything and you can make equal length driveshafts...just have to have a BEEFY jackshaft between the trans and t-case. Divorced case will also allow for whatever tranny you can source. Most medium duty have higher load rating multi-disc clutchs anyway, so it shouldn't be hard to get some grabby metallic/ceramic button clutch discs to put in and reconfigure the springs for a good clamp on. Then you'll just have to cobble together a good master/slave cylinder assembly for the third pedal so you can release it. Fairly straightforward, and shouldn't break the bank...
