Testing HPOP on 06 6.0L and hear bubbling in bottom of motor
Old Jul 24, 2010 | 01:59 PM
Wenuck72's Avatar
Default Testing HPOP on 06 6.0L and hear bubbling in bottom of motor
Hey need help with a stubborn 6.0L. It has new 90hp injectors, egr delete, new ipr valve, one piece STC, stand tubes, snubber valves, and dumby plug. I had it running poorly for 3 days and forgot to tighten the return line on the upper fuel filter housing. So I drove 40 miles home and turned it off and now it will not start again. I have pressre tested the HPO system and can only hear air bubbles from the pick up in the oil pan with the ipr closed. I have a HPOP coming Monday but was just looking for conformation that this bubbling is the sign of the weak HPOP. Thanks
Any info would be greatly appreciated, I have read every forum and can not find any info on this issue. Please reply
