where to get fabtech bushings or just new bushings
I would suggest the Cognito Sway Bar End Link Kit. You will probably have a difficult time removing the bolts as they usually get rusted or gaulded. Also this design is better than the current design you have due to the new pivot at the LCA.
"TURN YOUR STOCKER INTO A SHOCKER"
Whoops just noticed you've got a Dodge. Bushings can be purchased at a local 4wd shop. You could also get a heavy duty rod end style end link kit.
