ISSPRO EV 2 Fuel pressure gauge problem
Old Jul 19, 2010 | 11:35 PM
7.3 Cowboy's Avatar
Default ISSPRO EV 2 Fuel pressure gauge problem
when i put my guages in they all worked except the fuel pressure gauge and now my fuel pressure is stuck on 10 psi even with the guage unpluged. CAn some one help me?
Old Jul 19, 2010 | 11:56 PM
Sounds like a bad gauge.
Luke
Old Jul 20, 2010 | 01:53 PM
Michael's Avatar
The EV2 gauges will stay on their last position when you take away power, either by unplugging or turning off the ignition circuit.
Does the gauge home (turn the pointer down to the pointer stop counterclockwise) when you first turn on power? Do the lights come on? Complete troubleshooting instructions are here:
http://www.isspro.com/TROUBLESHOOTIN...leshooting.pdf
Regards,
Michael Pliska
Old Jul 20, 2010 | 03:12 PM
CSIPSD's Avatar
Did you just install them or have they been in for a while? On another post you said it was stuck at 100psi- typo or is it doing something different now?
As Michael said, once you remove power the gauge will stay where ever the power was removed from. Once you turn the power on it should do a full sweep and then return to 0 or where ever the reading is.
Old Jul 20, 2010 | 07:12 PM
7.3 Cowboy's Avatar
it was a typo. I will try to re hook it up and see if that helps
huntman7
Sep 4, 2015 04:49 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
