Hooking up a Aux fuel tank in the bed?
Old Jul 18, 2010 | 03:11 PM
7.3 Cowboy's Avatar
Default Hooking up a Aux fuel tank in the bed?
I have about a 30 or 35 gallon Aux tank i want to put on my truck and hook it up to the factory fuel tank. How did you guys that have them do this?
Old Jul 18, 2010 | 03:43 PM
Deezel Stink3r's Avatar
Get a Pollack 6way valve.
It does have 2 feed lines and 2 return lines switchable by a remote dash switch. So you need only the stock filter.
Now the cool thing: It does also have a fuel guage switch between both tank senders. So you need only the factory guage to read both, and all is controlled by that single dash main/aux tank switch.
Maybe you need a second lift pump.
Old Jul 18, 2010 | 03:53 PM
7.3 Cowboy's Avatar
What does it cost?
Old Jul 18, 2010 | 04:06 PM
around 55 bucks when it is on sale...
Old Jul 18, 2010 | 04:33 PM
7.3 Cowboy's Avatar
THanks for the info. I was thinking of a gravity flow system myself.
Old Jul 18, 2010 | 05:34 PM
gijohn45's Avatar
gravity flow is great if you put a switch on it... otherwise seeing the tank is above the fuel fill opening it will continue to fill the tank and let the excess drain out the filler until the level in the aux tank reaches the filler level....
if that all made sense....
Old Jul 18, 2010 | 05:38 PM
7.3 Cowboy's Avatar
It makes sense
Old Jul 18, 2010 | 06:22 PM
NadirPoint's Avatar
Originally Posted by gijohn45
gravity flow is great if you put a switch on it... otherwise seeing the tank is above the fuel fill opening it will continue to fill the tank and let the excess drain out the filler ...
No. I've had a gravity feed 30 gal under the toolbox in the '07 for over a year no prob. The rollover valve prevents any possible leakage as you suspect. The only issue in that regard is tapping a good leakproof connection into the main tank. I did it in conjunction with the vent mod and a three way valve. Very simple and reliable install, works great. Not sure how the Ford tanks work, but they can't be that much different.
Old Jul 18, 2010 | 11:03 PM
7.3 Cowboy's Avatar
Well we are gonna find out since im gonna install it tomorro im gonna T into my filler neck and run 1/2 hose from tank to the filler neck and have a manula valvle proboly a filter aswell
