where to plumb in fuel pressure guage?
Old Jul 14, 2010 | 08:36 PM
92typhoon937's Avatar
Default where to plumb in fuel pressure guage?
where do u guys put the sender for the fuel pressure at in the 12 valve motors i cant seem to find a suitable place to put it
Old Jul 14, 2010 | 08:47 PM
Red_Rattler's Avatar
High Tech Redneck
You can drill and tap the bajo bolt into the injection pump itself and it works great there. Just be sure the sender is seperated from the motor with a piece of rubber hose to keep from vibrating it to death. Also go with electronic if you can I have a mech on my 03 and hate it...
Old Jul 15, 2010 | 12:04 PM
96blackcloud's Avatar
i might have found a place i have the primeloc remote fuel filter and it has two plugs in it i assume one for the return line and one for the other would i plumb the gauge to the fuel line coming to the motor?
Old Jul 15, 2010 | 04:29 PM
i have an electronic one kept it out of my o7 puttin in the 97 so just drill and tap the bolt
do u really think it would hurt it that bad from the vibration being screwed into the banjo bolt
Old Jul 15, 2010 | 06:59 PM
As for the electric guage - put on a mechanical gauge - they are cheap and if you screw it up, you arent out $200+ Make sure you run a needle valve (open just a hair) or a pressure snubber to dampen the pulses from the P-7100.
Old Jul 15, 2010 | 09:38 PM
i already have the guage it was in my 07 i kept almost everything ihad on the truck and sold it when i traded it in
thank you very much for the pic
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
