95 5.9 in a Freightliner FL 70
Old Jul 13, 2010 | 11:23 PM
itsitspat's Avatar
Default 95 5.9 in a Freightliner FL 70
Looking @ buying a 95 Freightliner FL70 with a 5.9 Cummins. The truck ways 12,000LBS and I want to tow 20,000 LBS. The cummins out put is 190 HP with only 31,000 miles.It has a 6 speed trans. What can do to it, a friend says a Bigger Turbo? Need some Help! Thanks
Old Jul 13, 2010 | 11:54 PM
spoolinaround's Avatar
auto or manual? you can get a significant gain just with some pump tuning
Old Jul 14, 2010 | 12:24 AM
A bigger turbo isnt going to do much for you unless you feed it more fuel. a bigger turbo is only part of the equation. More air + more fuel = more power.
This will be the true medium duty version of the engine. Does it have a P-7100 injector pump? If so, theres lots you can do but you also have to weigh the fact that you want to tow heavy - so you really cant go crazy with the modifications.
Old Jul 14, 2010 | 12:43 AM
12valvetater's Avatar
As long as it has a 12mm pump and not an 11mm like they put in buses.
Old Jul 14, 2010 | 11:12 AM
itsitspat's Avatar
Default How do you find the size of the injector pump
I just called Cummins it has a Bosch 7100 pump,yes. My friend has a Halset Turbo off a 6 liter with eletronic waste gate, can I use it? Thanks
Old Jul 14, 2010 | 01:07 PM
itsitspat's Avatar
Default 95 stock 5.9 w/31,000miles towing20,000lbs
Looking @ buying a 95 FL70 Freightliner with a 5.9 w/31,000 miles 6 speed trans. The truck weights 11,000LBS and will be towing 20,000LBS. Everything is stock on the Engine it has Bosch 7100 pump. My friend has a Halset Turbo off a 6 liter that has a electric waste gate can I use it ?
Do you guys have any good ideas for getting more Power. Thanks
Old Jul 14, 2010 | 01:16 PM
NadirPoint's Avatar
If you are talking about an HE351 from a 6.7 Dodge, that would be a nice upgrade. Drawbacks are you would not have the variable vane exhaust brake function and it's a little tricky getting the wastegate to work without the Dodge electronics, but it can be done.
Old Jul 15, 2010 | 01:19 AM
itsitspat's Avatar
Default Need to get more power from a stock 95 5.9
Need some help to get more power from a stock 95 5.9 with a Bosch 7100 injection pump.Looking at buying a 95 Freightliner with 31,000 miles with a stock 5.9 Cummins. A friend has a Turbo from a 6.7 that has a electric waste gate. Thanks
Old Jul 15, 2010 | 03:18 AM
12vcummins96's Avatar
https://www.dieselbombers.com/5-9l-1...-12-valve.html
https://www.dieselbombers.com/5-9l-1...ning-mods.html
here are a couple things to start with
the turbo will not work
brand97
For Sale
Jun 30, 2015 09:14 AM
EasTxOilfields
Mar 31, 2015 09:03 PM
ronstop
Feb 26, 2015 09:48 AM
dezeldoc
For Sale
Feb 2, 2015 04:21 PM
Adam65
Jan 9, 2015 11:50 PM
