Will They Fit?
Old Jul 13, 2010 | 11:32 AM
rkadcock's Avatar
N.M. Bombers Director
Default Will They Fit?
I need some help from the 2nd Gen guys. I just got done doing my leveling kit on my 97 and Im ording my rims and tires but before I do I'd like to make sure they fit.
I'm getting RBP 94 wheels (5" BS and -12mm offset) and Toyo Open Country ATs 285/75R18(35x11.50R18) will those fit without any rubbing?
Old Jul 13, 2010 | 06:00 PM
MP03's Avatar
I believe you will be ok!
Old Jul 13, 2010 | 06:32 PM
00' Quad Cab's Avatar
With a 2" leveling kit my 33's will rub but this is with a 17x10 with neutral offset and 33x12.50's.
Old Jul 13, 2010 | 06:41 PM
BlackCloud96's Avatar
I have a 2inch leveling kit on my 96 2500 with 315/75/16s and the only time they rub is on the frame when i turn sharp!
Old Jul 14, 2010 | 11:32 AM
rkadcock's Avatar
Thanks guys for the replies! I'm thinking I should be fine but thought I'd check first.
Old Jul 14, 2010 | 11:53 AM
bobcat67's Avatar
285/75/18's aren't a 35" tire, they're a 33" tire, so you should be just fine, you could probably go even bigger like a 305 or 315 and still be ok
Old Jul 14, 2010 | 12:34 PM
rkadcock's Avatar
Really? I was just going with what Toyo had them listed as. According to them 285/75R18 is 34.8".. But now that I think of it, that's the almost the same size as I have now (285/75R16). Can a bigger rim actually change the size that much?
Old Jul 14, 2010 | 02:53 PM
J-Pipes's Avatar
It is a bigger tire, they still have the same ratio's as your 16" tires, but since it is on an 18" wheel that would make them about 35", you just have to factor in the extra 2" of wheel that you are running.
Old Apr 2, 2011 | 08:12 PM
blowinsmoke94's Avatar
i know my buddy has a stock 1500 with 33 10.50s and they dont rub
coach101
Sep 22, 2015 09:36 PM
landon025
Sep 8, 2015 09:21 PM
Jsully
Aug 31, 2015 07:55 PM
carmel
Mar 20, 2015 09:25 PM
Supremedragonx
Mar 1, 2015 01:50 PM
