HX40 turbo?
Old Jul 5, 2010 | 01:34 PM
Killacams's Avatar
Default HX40 turbo?
so i was thinking about buying a HX40. does anyone one know if there good or how much psi they get. i know stock ones get 35psi
Old Jul 5, 2010 | 08:00 PM
dan33klein's Avatar
i say 40psi. depends what you buy, a regular hx40 i believe has the 57mm wheel.
i have a super 40 that has a 60mm wheel.
it might be better to get a hybrid or convert yours.
depends what other mods you may want to do
Old Jul 5, 2010 | 10:01 PM
Killacams's Avatar
the one im going to get is a 60mm. and i see you have sdx injectors where did you get yours at?
Old Jul 5, 2010 | 11:31 PM
tltruckparts's Avatar
sdx injectors come from sdx theyre a sponsor on here. i had an hx40 before my phatshaft. i would have to say spend the extra couple hundred and get a little bitter turbo so you dont have to upgrade twice. i hated my hx40 only had it for 3 or 4 months before finally gettin a 62/65/14 best investment i ever made
Old Jul 6, 2010 | 12:25 AM
jrad989's Avatar
i wanted an hx40 for a while but heard too many horror stories about them. they are a weaker turbo. so i decided to save for somethin higher quality.
Old Jul 7, 2010 | 03:04 PM
SSpeeDEMONSS's Avatar
if youre going to get a 40 get a super 40. also need to remember that you cant bark it a lot or you are going to snap a shaft.
like previously stated, spend more now to get a better charger and not have to spend even more. it really depends on what exactly you want to do with the truck.
Garrett
Old Jul 7, 2010 | 03:45 PM
JIT's Avatar
JIT
You get buy a new wheel and front cover for your HX35 to make it a 60mm. I would do that before buying an HX40. The shaft will be the weak link and like mentioned before it will break if you bark it too much.
Old Jul 7, 2010 | 05:06 PM
dan33klein's Avatar
get a phat shaft!
Old Jul 14, 2010 | 07:54 PM
blackout94's Avatar
i had one that barked at 40 psi a couple times held up but dusted it lasted 3 months of abuse.
im not sure you will like the spool up tho with as little fuel as you have
Last edited by blackout94; Jul 14, 2010 at 07:54 PM. Reason: Automerged Doublepost
Old Aug 3, 2010 | 01:35 AM
chokeonmismoke's Avatar
i dont like em trust me been threw alota turbos the past few months jus save ur money and get a good one
