Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Need Help! Installing CP3 Fitting!!
Old Jun 30, 2010 | 09:10 PM
Snowman's Avatar
MR.3K
Default Need Help! Installing CP3 Fitting!!
Just got the PPE CP3 fitting. I have everything out of the way and i dont know what fitting to change. There are to fittings, one on top, and one on the back. Dont know what one!!! Or was i suppose to get two of the CP3 fittings??? HELP!
Old Jun 30, 2010 | 09:14 PM
kmkdiesel's Avatar
what fitting is it that you have exactly and we can help you out alittle more
Old Jun 30, 2010 | 09:18 PM
Snowman's Avatar
MR.3K
its the PPE CP3 fitting thats barbed. It never came with instructions!!
Old Jun 30, 2010 | 09:38 PM
kmkdiesel's Avatar
this is the stock fitting that you will need to pull out and put the new one in its place, you can see its right next to the fca
Old Jun 30, 2010 | 10:04 PM
Snowman's Avatar
MR.3K
Perfect!! Thank you so much! Now i can get it done tonight!!!
Old Jun 30, 2010 | 10:13 PM
kmkdiesel's Avatar
yep no problem glad I could help
Old Jun 30, 2010 | 10:46 PM
2500HeavyDuty's Avatar
yup repace the one kmk posted, thats the inlet port, the other one that points up that looks just like it is the return and the fat one is the high pressure output
Old Jul 1, 2010 | 04:20 PM
kmkdiesel's Avatar
also was going to ask this last night, how did you hook the hose up to it did you get a different hose for the fitting because the factory hose i am pretty sure will not work with the bigger inlet fitting, most places send you the fitting when you order a bigline kit or after market lift pump
Old Jul 1, 2010 | 07:21 PM
i never messed with one of those fittings ever, i wouldnt know
Old Jul 2, 2010 | 10:05 AM
Snowman's Avatar
MR.3K
i managed to get it on believe it or not! i was a pain But got it on and fired it up. I'm going to change that line yet just did it to get to work for now.
childs25
Chevy/GMC Duramax 01-04 LB7
May 10, 2015 01:50 PM
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
schwier94
17
Apr 7, 2015 03:16 PM
Cage
Pay It Forward
Mar 27, 2015 12:19 AM
schwier94
Mar 24, 2015 12:18 PM
