Truck missed, died now wnt start.
Old Jun 30, 2010 | 04:38 PM
svt28640's Avatar
Default Truck missed, died now wnt start.
I have a 2002 f250 7.3. other morning it missed an started loosin power then when i got off the road it died. So i changed he cps an run some fuel treatment. An it quit i drove it around for a few hours an brought it home. I drove my car to work today an when i got home fired my truck up. Didnt make it haalf mile it did same thing only now it want start back at all. Cranks an cranks an never offers to start. Any suggestions would be helpful
no engine light but plugged scanner in an got the followin.
1. 1280 unknown
2. 1249 unknown
3. 0603 icm kam (dL)
Old Jun 30, 2010 | 05:16 PM
theSLEEPER's Avatar
You might have a bad ICP sensor. Try unplugging it and see if the truck will start.
Old Jun 30, 2010 | 06:32 PM
svt28640's Avatar
Tried no luck
Old Jul 1, 2010 | 06:44 PM
svt28640's Avatar
Changed Oil. Checked oil in hpop an its not high as it should be. Do i need to add oil to it or what?
Old Jul 6, 2010 | 12:31 AM
acblair801's Avatar
Had touble where my truck would start cold but then loose power and not start warm. Turned out to be IPR problem. If you don't have a scanner like me check voltage at ICP. (PSI) (MPA) Voltage
0 0 .02v
200 1.5 .4v
400 3 0.73v
600 4 .96v
800 5.5 1.2v
1000 7 1.4v
1200 8 1.6v
1400 9.7 1.9v
1600 11 2.1v
1800 12.4 2.3v
2000 13.8 2.6v
2200 15.2 2.8v
2400 16.5 3v
2600 18 3.3v
2800 19.3 3.5v
3000 20.6 3.8v</pre><hr />
Only wire that varries voltage. While cranking need at least 450 psi to start. Hope this points in right direction.
doublehbar
13
Aug 9, 2015 12:35 AM
moose2j
Jun 21, 2015 12:36 AM
doublehbar
33
Jun 5, 2015 11:38 AM
clarthom
8
Mar 5, 2015 07:27 PM
ronstop
Feb 26, 2015 09:48 AM
