Dual Feed P-Pump
Old Jun 21, 2010 | 09:52 PM
Benjamin's Avatar
Bombardier
Default Dual Feed P-Pump
anyone have a write up on how to dual feed a P-pump......
Old Jun 21, 2010 | 09:54 PM
Red_Rattler's Avatar
High Tech Redneck
I can make one
Old Jun 22, 2010 | 04:58 AM
94 12valve's Avatar
remove the front plug above the mack plug, split the main feed line, run the second line into the front plug.
here is one pic I'll get some more tonight
Last edited by 94 12valve; Jun 22, 2010 at 04:58 AM. Reason: Automerged Doublepost
Old Jun 23, 2010 | 08:54 PM
Benjamin's Avatar
Bombardier
yes, more / better pictures please. so all you need is another fitting for the front and a "T" for the line? where can those be found at?
Old Jun 23, 2010 | 09:17 PM
High Tech Redneck
This is where I get all of my fuel stuff at. Call him qnd explain what you want to do and he'll hook you up, great guy to deal with.
Glacier Diesel Power
Old Jun 23, 2010 | 09:59 PM
94 12valve's Avatar
All you will need is a T fitting that can be found anywhere fuel line is sold, 4ft of fuel line will be more than enough, some push lock fittings, metric allen wrench to remove the front plug, and another fuel fitting I used -8. I should have wrote the thread size down
here is my "T" fitting. the blue line is comming from my AD 150. The top black hose runs to where the fuel line normally feeds the ppump, the second line runs to the front plug that has been removed.
Insert your -8 fitting to the front plug, here is where the second feed line will be connected
The normal feed
Old Jun 23, 2010 | 10:36 PM
94 12valve's Avatar
for a DD its really not needed, but for higher rpm trucks it will help. Also its cheep to do and very easy
Old Jun 23, 2010 | 11:31 PM
biged681985's Avatar
like a 4k rpm range? or for the ones turnin 5k?
Old Jun 24, 2010 | 11:04 AM
94 12valve's Avatar
IMO if your trying to fuel past 3500 than this dual feed will help. I also think the 160's and 175 pumps should be dual fed sooner than that
Old Jun 26, 2010 | 11:59 AM
Benjamin's Avatar
Bombardier
I'll be turning up to 4000-4200 maybe more but i'd rather have it and not need it than need it and not have it.
Edit: and my pump is a little bigger than a "stock" pump....
