98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
How to Update Smarty / Smarty Upgrade 1998-2002
Old Oct 1, 2007 | 01:01 PM
DB Admin's Avatar
Banned
Default How to Update Smarty / Smarty Upgrade 1998-2002
Well Ive tried a few times and never could get it to work ,,, Finally as i type its Updating my smarty ..
The tools on the mads site need reformatted to where you know what your doing im fairly computer savvy and its taken me an hour to figure it out and ive tried it a few times last year and couldn't do it ..
Im going to the
Smarty S-03. Ver. 1.22B Data 2.07A
Same as version 1 but with the TSB
for extreme cold climates and
driveablity enhancements for winter
fuel. ( For automatic trans. only )
And will see what it does
To Update ....
Dont even think about getiing your smarty plugged in ....
First Download this
http://www.madselectronics.com/downl...DM_2.00.00.zip
Save to your desk top
Unzip it to your desk top
This allows the puter to knwo whats going on here
You will need the Uploader ...
http://www.madselectronics.com/downl.../SmartyUSB.exe
This will take your update and push it threw the usb to your smarty
Now the update (Program File) .. Pick One and save to desk top
http://www.madselectronics.com/downl...EV1_22D107A.7z
Smarty S-03. Ver. 1.22B Data 1.07A
The original software as described on
Smarty's back side label.
http://www.madselectronics.com/downl...EV1_22D207A.7z
http://www.madselectronics.com/downl...EV1_22D307A.7z
Smarty S-03. Ver. 1.22B Data 3.07A
As version 1, but all the files # 0 have
been changed with an "anti theft"
software. On SW # 0 the engine will
crank but not start.
http://www.madselectronics.com/downl...EV1_22D407A.7z
Smarty S-03. Ver. 1.22B Data 4.07A
start, but die when a load is applied to
the engine.
Thats the Program Files ...
Now you will need to unzip the program files using 7zip
download...
http://downloads.sourceforge.net/sevenzip/7z455.exe
And Install
Once installed right click your Program file on your desk top and select 7zip and extract here
This transforms your program file to a file you can use
Now Plug your Smarty in Via USB
It will come up and say new hardware found just ignore all this
Right Click My Computer
Select Properties then Hardware then Device Drivers
You will see a USB Device with a Double click on it and select drivers Then click update driver and secect that I WILL SPECIFY LOCATION dont let it search for it ,,, then browse to Desktop and the Un Zipped CDM_2.00.00 Folder Hit Go
It will install the driver from there .... now Click on the installer SMARTY LOOKING ICON and click send ,,, it will prompt you for the file then go to the un7zipped Program File (.smt extension) and hit go it will then update your smarty
So you will need These Files/Programs ( All Are Separate )
7zip extraction program
Drivers
Uploader
Program Files
To Upgrade Your Smarty
DM
Old Oct 1, 2007 | 01:36 PM
DB Admin's Avatar
Banned
I got a new Speed Limiter Screen What Input am I suppose to put here?
The new software removes the speed limiter for the 2001 and 2002 trucks
The smarty now offers the ultimate valet switch set the maximum speed from 25 to 250 mph
This new program is also showing higher rpm fueling too.
I guess I should put 250 in the speed limiter I left it on stock , i got smoked a few weeks ago cause my truck was DUN at About 115 it just wouldnt fuel anymore I guess i know why WOOT !!!
Old Oct 1, 2007 | 01:54 PM
DB Admin's Avatar
Banned
I couldn't take it no more i went and reprogrammed it to 250 MPH top Speed I think stock is around 115
Old Oct 3, 2007 | 09:53 AM
Ben's Avatar
Ben
A link I found I DTR.....Even better instructions......With pictures...
SMARTY HOW TO
