smoking problems's
Old Jun 24, 2010 | 10:34 PM
xxxextremedieselperf's Avatar
Default smoking problems's
o.k so heres the deal my friend has a 1996 dodge cummins 2500 4wd automatic he's took the plate out cranked the star wheel has straight exhaust stock injectors aftermarket intake and is wandering why it doesnt hardly smoke at all any ideas? ive replaced the fuel filter twice and he's did everything he can to make it smoke alot and it just dont smoke any help would be appreciated thanks
Old Jun 28, 2010 | 09:04 PM
no one ? any takers?
Old Jun 29, 2010 | 02:35 PM
derek a.k.a wenie's Avatar
i have a 95 and my buddies truck that i have done all the work on is a 98 both 12v autos but when i pulled the plates and cranked the star wheel on both of them they smoked a litttle but not a cloud the auto won't load up the truck like a standard will unless you put in a lock up switch in it and still its not alot if you want smoke your gonna need either injectors or delivery valves atleast then you'll see some good smoke
Old Jun 29, 2010 | 05:46 PM
tltruckparts's Avatar
throw some big injectors on there and you have the opposite problem. too much smoke
Old Jun 29, 2010 | 05:49 PM
00CumminsMan's Avatar
Get 100hp jammer's, she should roll smoke then
Old Jun 29, 2010 | 06:26 PM
az coil roller's Avatar
YOU CANT PUT JAMMERS IN 12 VALVE
Old Jun 29, 2010 | 06:30 PM
exactly those are 24v injectors. not to mention there are a ton of good companies that make injectors for 12 valves
Old Jun 29, 2010 | 06:33 PM
My bad. i ment 100hp injector's
Old Jun 29, 2010 | 06:43 PM
BlackCloud96's Avatar
Different D-valves will help
Old Jun 29, 2010 | 06:57 PM
joey's Avatar
move the afc all the way foward and take the spring out of the afc
