transmisson
Old Jun 23, 2010 | 01:04 AM
the cummins's Avatar
Default transmisson
Alright guys im new to here and have a couple questions i want to upgrade my tranny in my truck with a tc vb and shift kit if necessary. But im sorta on a budget and was wondering whats a good but cheap tc vb and shift kit out there. thanks and heres a couples pics of my truck on 20s and my welds Name:  Picture551.jpg
Size:  258.1 KBName:  Picture552.jpg
Old Jun 23, 2010 | 02:07 AM
cmns2500's Avatar
DTT Performance Diesel Transmission and Power Accessories
Old Jun 23, 2010 | 10:55 AM
glfredrick's Avatar
The two words "cheap" (or inexpensive) and "good" don't work well together for our needs.
Least expensive way to go is to build your own valve body using a kit like the TFT-Diesel kit from Transgo. Billet single disk torque converters start at about $500 and go up from there. WIT (Whatever It Takes) offers a billet single disk converter for under $300, but it is of unknown quality. It is built by a major builder and they've not had problems with returns (I live in Louisville, the home base of WIT and have talked to the builders). I'll probably run one of theirs in my own truck. FYI, I'm just looking for a reliable tow rig, not a big hp smoker, so my needs may vary from some of the other users on this board.
Old Jun 23, 2010 | 12:34 PM
Well wat would u guys recommend if on a budget just to push some power
Old Jun 23, 2010 | 01:08 PM
94 12valve's Avatar
how much is "some" power and what are you calling a "budget"?
Old Jun 23, 2010 | 03:07 PM
350 400 Basically wake thing up and 1000 to 1200 for parts
Old Jun 24, 2010 | 09:03 AM
glfredrick's Avatar
Before I post, I want to say that this is my opinion and that others will probably have something different to share...
That being said, I see a break between 300-350 and 350+ in horsepower as far as the needs in a transmission build. At 350, you can get by with a single plate billet torque converter and a valve body, easily done for your $1000 budget. Get with any of the great vendors on this board and ask them for a quote. At 400 and up, you are looking at a triple disk billet converter (over $1000 itself), a valve body ($250), billet input shaft ($750), high end clutches, steels, bands, etc., (another $300) and perhaps a billet output also ($500).
Adding power = adding torque and it is the high torque that starts taking stuff apart. At 300-350, you are probably in the 700-750 pounds/feet range for torque. Go to 400 and you are probably nearing 1000 pounds/feet -- above the designed parameters for the transmission, hence the additional parts to handle the load.
You'll probably also need additional cooling for either build.
So, up front, so as to not waste a bunch of money with a build that just has to be done over, you might want to consider just how much power you want to make and plan accordingly. Our trucks readily take to power -- and it is relatively easy to build for power, but if you want to play, you have to pay. There really are no shortcuts in this process as any number of people who have gone before you will attest.
Old Jun 24, 2010 | 02:22 PM
Heres my plan that all i want to do with the truck fuel plate 4 gsk and 50 are 75 hp injectors and maby laser cuts and later on a turbo
Old Jun 27, 2010 | 05:51 AM
Drothgeb's Avatar
The trans on a 95 is going to require some internal work to handle a shift kit and that much power. You should probably rebuild.
Old Jun 27, 2010 | 10:20 AM
cumminspwr11's Avatar
the inside of the trans is ok for that power range, around here i can get a single disk dacco convertor for $350 or $400 and a kick *** vb from dtt or ats for $420, the bad thing with the 47rh is that the line seals for lock up are weak so you cant run alot of lock line pressure on the stock seals, all the good internals parts are cheap compared to the vb and tc, you could get all the good clutches and seals and get the upgrades to put more clutches and steals in each pack for under $200, its the labor that will kill you
if your going to stay in that power range a single disk and vb will do you just fine imo as long as the rest of the tranny is still good and not on its way out
