AutoMeter Tranny Temp Gauge?
Old Jun 15, 2010 | 11:52 PM
LB7DuramaxMeggers's Avatar
Default AutoMeter Tranny Temp Gauge?
i have an 01 duramax, i ordered a set of gauges and the only one i cant figure out is the transmission temp, it came with 3 different fittings but to be honest im completely clueless on what to do.. help??
Old Jun 16, 2010 | 09:12 AM
Rttoys's Avatar
Use the one GM provided in the cluster........
Old Jul 22, 2010 | 02:20 PM
yg_d-max18's Avatar
The three different fitting are just adapters for a size of your choice. You will have to drill and tap your pan and have the adapter welded or brazed to the pan. If I recall you have to use one of the adapters so that you are not welding the sending unit.
Old Jul 22, 2010 | 03:42 PM
bftrain's Avatar
is the stock one broken or something?
Old Aug 6, 2010 | 02:19 AM
stock reads 280 at all times.
Old Sep 14, 2010 | 05:32 PM
gotstreetracin's Avatar
sounds like the stepper motor in the cluster is bad......
JDurks2
16
Jun 7, 2015 08:57 PM
doodieroot
May 10, 2015 11:48 PM
wilki
Feb 12, 2015 09:04 AM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
tbreddiesel
Thoroughbred Diesel
Feb 3, 2015 03:31 PM
