Knocking louder then normal really bad when I get on it?
Old Jun 13, 2010 | 06:14 PM
Tpaine22's Avatar
Default Knocking louder then normal really bad when I get on it?
I jus bought an 02 duramax, it's a great looking truck but it knocks really loud when ever I get on it... Is there any thing wrong with it if so what should I look for? Thanks fo the help.
Also some times it will lock into third gear till I let off the throtle...what causes this?
Old Jun 14, 2010 | 10:36 AM
K50's Avatar
K50
Fuel filter good? Injectors good? I'd check the balance rates of the injectors. If it's knocking you might have an issue there.
Can you check for any trouble codes? No check engine light?
Old Jun 14, 2010 | 01:30 PM
Tpaine22's Avatar
I haven't had any check if any things wrong yet I was waiting on a reply to see what I should have checked, I'll have all that checked including if it's trowin codes... Do you know any thing about the third gear locking?
Old Jun 14, 2010 | 01:50 PM
K50's Avatar
K50
Well third gear locking sounds to me like it's going into limp mode; but I'm not sure why it would do that without throwing a code or turning the check engine light on.
I'm not sure what else to recommend...hopefully one of the other guys will throw down some more ideas.
Old Jun 14, 2010 | 04:26 PM
Tpaine22's Avatar
Alright well I'll get every thing else cheked and see if any codes, would gettin a tuner help relearn those gears? An thanks for your help!
Old Jun 14, 2010 | 05:10 PM
K50's Avatar
K50
How about fuel pressure/fuel pump? If the injectors are getting starved of fuel that could also cause a limp.
Some tuners have a re-learn or fast learn function for the transmission but if it's a fuel related issue that won't help.
No problem man I hope you get it worked out!
Old Jun 14, 2010 | 07:13 PM
Tpaine22's Avatar
I'm going to buy a fuel filter right now and put in. If it dosent help I'll take it in the morning and have a buddie plug his computer in to it... Like I said the check engin lights not on so idk....
Also does the banks 6 gun have tat relearn for my gears sticking? Or what about a shift kit or shift enhancer
Old Jun 15, 2010 | 12:00 PM
K50's Avatar
K50
I don't think the Banks 6 gun has a fast-learn or re-learn feature. I know that PPE's tuner has one but not many of them do as far as I know.
Try the new fuel filter first and see if that helps.
Old Jun 24, 2010 | 07:22 AM
dmaxtothemax's Avatar
Keep us informed if you can, cause i have a very slight knock and was kinda hoping this convo would help... I also need to change my fuel filter - maybe i'll do that and see if my knock goes away...
Old Jun 24, 2010 | 09:55 AM
K50's Avatar
K50
The knock I had ended up being an injector. Hopefully for you guys it's as cheap and easy as a filter replacement. Injector failure sucks!
