10 k resistor hpop trick
Old Jun 11, 2010 | 04:45 PM
stephenjr's Avatar
Default 10 k resistor hpop trick
I have the adrenaline hpop but for some reason truck lope sometimes when i first start it. So i was thinking its the hpop. So i tryed the 10k resistor mod i used a radioshack it said 1/4 watt 10k ohm i put it where it says to put it and it had a rough idol not as lopy but just rough. Anyway should i have to do that mod with the adr. hpop. It did seem snappyer and a tad faster i think. I have a snap-on obd code reader/tester and i wanna try to see where my pressures are at. does anyone know where and exactly where to go on this unit. its not the sotice unit. its a older one i beleive red, hand held not the wide one its tall. Sorry i cant get the model # now my neighbor has it.
Old Jun 11, 2010 | 05:06 PM
CSIPSD's Avatar
I have no idea, but you need to pull the 10k... There junk. Will just jack up more crap!
Old Jun 15, 2010 | 06:50 PM
BeauH's Avatar
are you running a chip?
Old Jun 16, 2010 | 07:13 AM
theSLEEPER's Avatar
Do you have an auto trans?
Old Jun 16, 2010 | 01:23 PM
stephenjr's Avatar
yes auto trans, and yes a ts chip
Old Jun 16, 2010 | 07:37 PM
BeauH's Avatar
if i remember correctly the ts chip has the 10k mod in it
Old Jun 16, 2010 | 08:09 PM
CSIPSD's Avatar
Any chip already boost the HPO to the max the pump can handle. There is no reason for you to do the 10k mod, unless you like to see the SES light on all the time? LOL
Old Jun 17, 2010 | 08:03 AM
theSLEEPER's Avatar
The 10K mod on top of a chip does nothing but make your throttle touchy and your shifts shitty.
Old Jun 17, 2010 | 12:02 PM
stephenjr's Avatar
thx guys
