Nitto Trail Grappler + 1 ton = ???
Old May 26, 2010 | 11:15 PM
Bad93Cummins's Avatar
Default Nitto Trail Grappler + 1 ton = ???
Will these tires hold up on an F350 4x4 7.3 powerstroke? My buddy has a set on his 04 Z71 and loves them. They also look sweet and perforom well off-road!! Just curious if id beable to get any life outa them on an F350? Im looking at the 35x12.5x18, They are load range E and 10ply tires
Tire Details - Discount Tire Direct
Also is there anywhere else I could find tires for cheaper?
Old May 27, 2010 | 01:42 AM
FordDZLMan9191's Avatar
E load range should hold up just fine. Just remember that the more aggressive the tread pattern, the shorter the life if you run them on the road a lot.
Old May 27, 2010 | 09:01 AM
trucky's Avatar
there e load range
so yes they will work
Old May 27, 2010 | 11:06 AM
Yea I knew they would work, Just seeing how long they'd last.
Best price I have found for them are $297 a peice from discounttire. com or atlantic tire center for $1310 fully installed
just ordered them
Last edited by Bad93Cummins; May 27, 2010 at 11:06 AM. Reason: Automerged Doublepost
Old May 27, 2010 | 11:59 AM
5.9Bronco...eventually's Avatar
oh man. I was just going to comment on them. I think they look like a cheaper tire. At least that is my .02. You might have looked at nextag.com they always have prices from every site available. I found some pretty expensive tires for fairly cheap on there.
Aug 3, 2015 12:10 PM
Mar 7, 2015 04:00 PM
Nov 16, 2014 06:10 PM
