help with trouble code
Old May 25, 2010 | 07:44 AM
codiesel's Avatar
Default help with trouble code
so my truck is a 99 f 350 7.3 and it has been giving me trouble codes when i start it and it runs weird and i dont know what they are and what to do about it
the codes are
p1316 : injector cotrol moudle codes detected
p0306 :internal control moudle keep alive memory (kam) error
any help would be great thank you
Old May 25, 2010 | 02:34 PM
theSLEEPER's Avatar
Sounds like possibly IDM problems... What about if you return it to the stock tune? Same thing? P0603 is normal. Most likely caused by your tune...
Old May 25, 2010 | 06:12 PM
codiesel's Avatar
yes i returend it to stock and it is still throwing P1316 code but it only does it for like the first 5 10 mins the truck runs then it clears and the truck runs fine untill the nexted day and it does it agin any ideas were i can start to try and figure out the problem
Old May 25, 2010 | 06:17 PM
CSIPSD's Avatar
Try an injector buzz test, cylinder contrubution test and a KOER test... You will need someone with Auto Enginuity to do this...
Old May 25, 2010 | 06:41 PM
codiesel's Avatar
i will do so butr what could it be that it doesit for a bit then goes away and runes fine
Old May 29, 2010 | 12:29 AM
Chvyrkr's Avatar
You'll need a scanner to narrow down what it could be that causes it to run badly for a bit, then clear up.
Otherwise we're shootin in the dark.
Old May 31, 2010 | 10:39 AM
codiesel's Avatar
ya im working on getting a scanner but my buddy wantgs me to bring it to his house and by the time i get there it clears its self
Old May 31, 2010 | 10:57 PM
Chvyrkr's Avatar
Well, shut it down and have a beer.
Then try it again.
Old Jun 7, 2010 | 02:18 PM
TorqueIsMyFriend's Avatar
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Bighouse
Apr 9, 2015 06:51 PM
UC Kid
Nov 7, 2014 10:56 PM
