in tank fuel pump?
Old May 19, 2010 | 07:01 PM
94cummins12v's Avatar
Default in tank fuel pump?
did the 89,90,91 f350 7.3l have any in the tank pumps? or anything to cause a restriction?
Old May 19, 2010 | 08:48 PM
Sycostang67's Avatar
Nope, the IDI used only a block mounted pump. The gas trucks had in tank pumps.
Old May 19, 2010 | 09:49 PM
poocher pup's Avatar
only restricion if pickup screen got clogged somehow.
Old May 20, 2010 | 07:24 AM
maybe the tak selector valve is toast?
Old May 20, 2010 | 08:56 AM
DieselCrawler's Avatar
could be. unhook it and bypass the lines around it to test.
Old May 20, 2010 | 07:26 PM
how do you unhook the lines any special tool? they look like nylon tubbing like air brake line how would you bypass it, i have an extra valve but it hooks up with rubber hose i need to get this truck running asap for hauling
Old May 20, 2010 | 07:42 PM
i didnt need special tools to unhook my lines. just slide the little clip out of it and pull the fitting off. clip will be a different color plastic.
Old May 21, 2010 | 07:28 AM
oh ok thats what that is any i will try that tonight to see what happenes
Old May 23, 2010 | 08:18 AM
ok i was aable to take the lines off the valve and you can blow threw all 6 ports just fine, my budy also said that he has had to replace his in the tank pumps on his 95 powstroke, i thought the diesels did use them
Old May 23, 2010 | 11:46 AM
Everything on the PSD is electronic, the IDI's are all mechanical.
