INJECTOR HELP!! NEED NEW ONES
Old May 19, 2010 | 07:18 AM
jumpnjed's Avatar
Default INJECTOR HELP!! NEED NEW ONES
Ive been wanting new injectors for a while now. I have decided to start doing some chekin around to see what brand and size I would need. I use my truck alot to pull my 26' steel horse trailer in the mountains and on flat land. My truck isnt heavily modified. It has a 100 plate with afc slid forward and starwheel all the way, straight piped and a amzoil air filter. I want some better performance for towing and playing around a lil. Which injectors would yall suggest would do me the best?
Old May 19, 2010 | 08:36 AM
12vcummins96's Avatar
with stock charger i would say a 5x.012 max will be a little smokie but with the afc modified it will clean up nicely
if you want to go higher like a set of 5x.014s i would recommend at least a 64/71/14
if no charger added they will be way to hot for your liking
Old May 19, 2010 | 09:09 AM
jumpnjed's Avatar
Yea its a stock charger and rite now I dont have the money to uprgrade on that. Which brand would be the best and most cost effective to go with? Any other suggestions out there?
Old May 19, 2010 | 09:16 AM
94 12valve's Avatar
do you have the 215 pump or the 180?
if you have the 215 I would stick with the stock injectors
Old May 19, 2010 | 09:28 AM
jumpnjed's Avatar
Im thinkin its the 180 but not sure.. Im assuming your meaning 180hp cummins? rite?
Old May 19, 2010 | 11:01 AM
94 12valve's Avatar
yes if you have an auto its the 180hp pump, the sticks came with the 215.
Old May 19, 2010 | 12:13 PM
jumpnjed's Avatar
ok thats what i figured.. I was just makin sure.. Yes its the 180 pump... What injectorse would yall suggest then?
Old May 19, 2010 | 01:02 PM
94 12valve's Avatar
for towing I would keep the stockers and upgrade the trubo.
try a set of gov springs first before you go buying injectors, they make a world of difference
Old May 19, 2010 | 01:32 PM
jumpnjed's Avatar
Whats an average price of the springs and are they hard to put in?
Old May 19, 2010 | 01:57 PM
cumminspwr11's Avatar
i agree with 12valve on the springs-they make a huge dif.
no they arent too bad-if you can do a plate you can do the springs, they are around 100bux and should come with directions, if not they are on here somewhere, just make sure you take your time-dont try and rush thru it
do u have any gauges yet?
