Fuel return line
Old May 16, 2010 | 10:34 PM
dolmstead2007's Avatar
Default Fuel return line
Okay guys Im finally getting around to fixing the fuel leak on my 92. Its coming from the plastic fuel return line covered with a rubber hose that leaves the back of the engine and meets down on the frame rail below the seat with the metal return line running the rest of the way back.
Where can i get a replacement? My Ford dealership looks at me stupid anytime i go to order parts. The same dealership that said my truck doesnt exist and a 7.3 and zf5 were never availible in 88 so i have no confidence in their parts man. Would i just be able to run a rubber hose all the way down since i assume it was to allow for engine movement in the first place.
Old May 17, 2010 | 03:21 AM
Sycostang67's Avatar
I see no reason a rubber hose wouldn't work. Just make sure it cant rub on anything, maybe even put a plastic sheath on it to help protect it.
Old May 17, 2010 | 10:52 AM
Indianafirefighter1972's Avatar
Scheid Diesel has a kit for that, I just did it for my 93. They are on the web cheapp-gas.net the fuel return kit cost me $32.
Old May 17, 2010 | 05:46 PM
Just to make sure im clear its not the little short hoses that go betweent he injector fittings that i need. Its the one that comes off the back where both sides of the returns meet and head down to the frame
Old May 17, 2010 | 09:07 PM
DieselCrawler's Avatar
yea, mine is rubber. no issues.
Old May 21, 2010 | 09:19 PM
Default fuel line size?
Does anyone know what size that fuel return line is? I cant make up my mind if its 1/4 or 5/16. DieselCrawler do you know?
Old May 22, 2010 | 01:10 PM
not sure on the line running down the back, i belive it is 5/16. but dont quote me on that.
Old May 22, 2010 | 07:10 PM
Default FIXED
You were right Crawler it was 5/16" A little 5/16 steel brake line to replace the plastic piece and some new rubber and its back up and runnin.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
|WYG|SS
May 7, 2015 04:57 AM
|WYG|SS
Apr 28, 2015 03:59 PM
moneypitk5
Feb 12, 2015 11:01 AM
