Still no smoke! WTF!
Old May 7, 2010 | 01:04 PM
Reconn1's Avatar
Default Still no smoke! WTF!
2006 5.9l, Edge Juice+Attitude, S&B CAI, 5" straight pipe. Wasn't getting much smoke with that set up, so I was advised to upgrade lift pump. Put in a new PPE 160gph 12psi pump, but still no substantial smoke like other's have. Any advice?
Old May 7, 2010 | 01:37 PM
CreeperSleeper's Avatar
Injectors? Smoke switch?
Old May 7, 2010 | 02:43 PM
Reconn1's Avatar
Neither. But my buddy has a half the upgrades I do, and he has twice the smoke. Just wondering if I have something failing, or something else.
Old May 7, 2010 | 04:25 PM
SD207434's Avatar
something is not working properly. The higher the setting on the programmer the more smoke usually. As is the case with mine. I just have to look out for the cops I don't want a ticket.
Old May 7, 2010 | 08:09 PM
Red_Rattler's Avatar
High Tech Redneck
Automatic? If it is I bet you are slipping it and it's not puttin a load on the truck.
Old May 7, 2010 | 09:46 PM
dangerous1965's Avatar
Get a Smarty!
Old May 7, 2010 | 10:14 PM
mopo824's Avatar
make sure your edge is set to most responsive and not least
Old May 8, 2010 | 12:17 AM
Check your connections..... The EJWA should blow some smoke.
Old May 8, 2010 | 12:30 PM
tdub's Avatar
im in the same boat as you. '03 dodge with the edge juice w/ attitude and its not very impressive. is the S&B cai worth the buy??
Old May 8, 2010 | 01:04 PM
High Tech Redneck
Impressive as in power or smoke output?
