Mighty Diesel Visit - Mighty Diesel
We Now Have 6.7L "STREET-GATE" 38mm Wastegate Kit
Old May 6, 2010 | 10:19 PM
Mrs. Diesel Pap's Avatar
Site Sponsor - Mighty Diesel
Default We Now Have 6.7L "STREET-GATE" 38mm Wastegate Kit
“STREET-GATE” Single Entry 6.7L Wastegate System
We Now Have 6.7L "STREET-GATE" 38mm Wastegate Kit-gdp-sg67-38mm-7510_1266106356.jpg
Eliminate high drive pressure with the new GDP “Street-Gate” Single Entry 38mm Wastegate System!!!
While fueling options abound cost effective turbo options for the 6.7L Cummins are lagging far behind. The stock VGT turbo is an extremely tough design with the added benefit of a built in exhaust brake. However, it is very limited in exhaust flow capability due to the 2.44” turbine outlet opening and lack of a built in wastegate to bypass the turbine wheel. The GDP “Street-Gate” System solves that problem!
Tell any professional engine builder that you want to make additional HP from a turbocharged 6.7L engine while exhausting thru a 2.44” opening and they will laugh you out of the shop. The only way to add exhaust flow area, while maintaing the VGT turbo, is to add an external wastegate. You can pump all the air and fuel you want into the engine but to make horsepower you have to be able to get the spent gasses out of the engine in a hurry. The “Street-Gate” adds flow area via a Tial 38mm MV-S wastegate which controls drive pressure and greatly reduces pumping losses on the top end. All while keeping the built in VGT exhaust brake 99% effective.
The “Street-Gate” wastegate system works on all 6.7L Cummins application. For high horsepower applications we recommend the GDP “Pro-Gate”.
“Street-Gate” 38mm Wastegate System
- Simple single entry design for easy installation
- Vertical Gate Mount Design eliminates cracking seen in side mount designs. Weight of the unit is supported in an upright position.
- Eliminates High Drive Pressure which increases HP and TQ on the top end
- Reduces Pumping Losses
- Simple Bolt-on Installation. Replaces the rear EGR block-off plate.
- Made in the USA Tial MV-S 38mm Wastegate
- High Temp Coating on all Tubing
- True Air Pressure Regulator for Gate Control (with valve cover mount)
- Downpipe Support Bracket. Eliminate vibration in the downpipe.
Kit Includes:
Tial MV-S 38mm wastegate, High Temp Coated tubing kit, downpipe support bracket, air-pressure regulator with valve cover mount, true quick connect airbrake fittings and tubing, all needed mounting hardware and factory gaskets.
ORDER YOURS TODAY http://mightydiesel.com/catalog/index.php?cPath=119&osCsid=aja5k08pdghsg6t8p7embie 2n3
OR CALL 877-354-7008
Old May 7, 2010 | 09:11 PM
diesel pap's Avatar
bump
Old May 7, 2010 | 09:40 PM
captain_stabbin's Avatar
badass
Old May 7, 2010 | 10:22 PM
diesel pap's Avatar
i am going to put this on my 6.7
Old May 9, 2010 | 06:44 PM
diesel pap's Avatar
this is the one i think i will get for towing
Old May 11, 2010 | 10:11 PM
diesel pap's Avatar
bump
