Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Adrenaline 4K
Old May 6, 2010 | 12:46 PM
FormerVendor
Default Adrenaline 4K
The Quadzilla Adrenaline 4K is now available for the 98.5-02 Cummins.
This also includes the new V2 Pulse Monitor. The V2 Pulse is an updated version of the original Pulse montior with more memory, better processing power and new updated buttons.
Already have the Adrenaline? Upgrade to the new 4K box!!! Depending on the age and condition of your current Adrenaline it can cost $0-$150 to upgrade.
Old May 8, 2010 | 09:06 PM
FormerVendor
The most powerful and user adjustable power enhancement for the 98.5-2002
Cummins powered trucks JUST GOT BETTER! This new module allows you to extend your
RPM Range out past 4,000 RPMs! It also eliminates the pesky Torque Management on most pumps. This is the smoothest, most powerful and most adjustable product on the market for your truck! Nothing else is even close! Coupled with the new Pulse V2 you now have full control of your rev limiter and injection pump! The new V2 comes in a new aesthetically pleasing design with tons of function built in. The new display has an integrated AMPS mounting pattern for use with tons of vehicle mounting applications, newly designed buttons for better feedback, a quick disconnect plug, more onboard memory and twice the processing speed of the previous Pulse.
This is a MUST HAVE for all serious sled pullers and drag racers.
You will have an immense advantage over your competition.
The Adrenaline 4K will be offered both as a new kit and as an upgrade option. If you already own an Adrenaline and would like to have it modified to be a 4K box, please go to the Quadzilla Adrenaline 4K Upgrade page listed on the Quadzilla homepage. Charges for the upgrades for existing owners will range from $0.00 - $150.00 (plus shipping) depending on the serial number and age/condition of your Adrenaline.
The $150 upgrade charge on older boxes will include a brand new board as well as a new 1 year warranty.
Once an Adrenaline is made into a 4K box, it will only work with the dedicated 4K tunes. Previous tunes (such as the Beta, 1000, and 2000 series) will not work on the Adrenaline 4K or Pulse.
Your Pulse Monitor must also be updated (online software available) to the 4K software in order to work with your Adrenaline 4K.
In order to modify an existing Adrenaline, your board will have to be sent to Quadzilla for modifications that can only be performed by a Quadzilla Technician.
The 4K programming completely takes over the VP44 control and therefore may not be as smooth as a regular Adrenaline module. The Adrenaline 4K is intended for OFF-ROAD use only and are not to be used on any public roads or highways.
The Adrenaline 4K is not intended for stock trucks: AFTERMARKET VALVE TRAIN MODIFICATIONS REQUIRED AT THE MINIMUM. INTERNAL ENGINE MODIFICATIONS ARE ALSO RECOMMENDED. The Adrenaline 4K will set a Check Engine light and may be rough in areas approaching the factory rev limiter. The Adrenaline 4K is intended to be used in conjunction with a Pulse monitor.
Adrenaline 4K with Pulse Monitor V2 $719.20
Upgrades on modules with a serial # prior to 63553 will be a $150 charge.
Upgrades on any modules with a serial # between 63553-70200 will be no charge.
All serial #'s after 70200 will not be eligible for upgrade.
KatiTrimmell
Jun 13, 2016 12:29 PM
dodge1998
Jun 13, 2016 12:25 PM
MAC4232
Oct 16, 2014 04:22 PM
