Pitman arm
Old Sep 18, 2007 | 07:11 PM
redneckbuckeye's Avatar
Default Pitman arm
Anyone have any honts as to how the hell you get a pitman arm off of a 2000 chevy K2500? I can't get the dang puller in to get the dang thing off.
Thanks Nate
Old Sep 18, 2007 | 08:33 PM
Whit's Avatar
Site Mascot
how bouts one of them fork jobbers and a good 2lb double jack
Old Sep 18, 2007 | 09:06 PM
I thought of that, but don't have one, I'll try to get one tomorrow.
Old Sep 19, 2007 | 08:11 AM
Johnny Cetane's Avatar
i think one of the guys i worked with had figured away to remove the steering shaft and all but one of the mounting bolts from the box so it would tilt ever so slightly and you can get a puller on. i don't know if this works or he ever perfected it. i've always had to pull the box to get it.
Old Sep 19, 2007 | 12:46 PM
DangerousDuramax's Avatar
DO NOT USE A PICKLE FORK ON A GM HD TRUCK!!! You MUST use a puller. The steering boxes in our trucks have a cast aluminum top on them. There are gears in the box so when the steering yoke moves the gears move with them.
Problem: The gear that has the pitman arm on it is held in the center of this box via a stud that goes through the top of the aluminum cast top. There is a set nut on the very top of your box. When you pound a pickle in there, it strips the cast top out. This causes the gear to fall to the bottom of the box and rest. Now when you turn your wheel, it will turn in both directions fine but your steering wheel will not find center on its own when you come out of a turn.
Its quite easy to take the bottom two bolts out of the steering box and rotate it back to get the puller on. At this point you may as well pull the whole thing out because there is only one more bolt and the fender liner to remove.
Old Sep 19, 2007 | 12:50 PM
Whit's Avatar
Site Mascot
OH GEEZE........I'm glad you piped up, we coulda messed things up here
cheers to ya DD
Old Sep 19, 2007 | 12:51 PM
Dont ask me how I learned about this.
Old Sep 19, 2007 | 12:58 PM
Whit's Avatar
Site Mascot
ah yes........school of hard knocks eh
I been there to dont worry its all good
Old Sep 19, 2007 | 02:40 PM
I was wondering if I just pried it off, if it would mess something up. Thanks for all the info.
Old Sep 19, 2007 | 02:43 PM
GRI's Avatar
GRI
the pullers are lioke $10 at advanced auto. the puller plus a little heat will do the trick. notice I said a little heat. otherwise you could burn the shaft seal.
