2 Stroke with the fuel. good or bad?
Old Apr 23, 2010 | 05:36 PM
jshblain's Avatar
Default 2 Stroke with the fuel. good or bad?
hey guys what up? ive herd alot about adding 2 stroke oil into the fuel with the cummins but is anyone doing it with the 7.3l and what are the pro's and con's? is there a noticable differince?
Old Apr 24, 2010 | 02:43 PM
stephenjr's Avatar
Its ok it lubes the pumps, you can get away with one qt to a full tank. I use to run used motor oil but it started clogging my filter. But your good go for it! The 7.3l eats anything, tranny fluid. You wont notice a performance diff.
Old Apr 24, 2010 | 04:39 PM
jshblain's Avatar
ok cool thanks. i know guys that put in an ounce for every gallon. any info on that?
Old Apr 24, 2010 | 04:44 PM
stephenjr's Avatar
That could get expencive, cheaper to use diseal but should work too.
Old Apr 24, 2010 | 05:39 PM
powerstroke cowboy's Avatar
it will maybe run better and get a "LITTLE" better fuel MPG. it all depends on the pickup and the quality off fuel you have in it.
Old Apr 24, 2010 | 06:24 PM
CSIPSD's Avatar
Powerstroke does not "eat" anything and unless you like buying injectors you should be very careful with what you put in...
Some two stroke is not going to help or hurt anything, but be careful with tranny fluid and oil.
Old Apr 24, 2010 | 09:41 PM
O yea do not put ATF tranny fluid in your fuel. Bad things can happen
Old Apr 26, 2010 | 01:01 AM
kegs99's Avatar
i've heard 2 stroke in a cummins will not get compression as good? what are all the risks with this? what are the upsides? can't decide if i should run it or not. my trucks at 193000 miles and still runnin good...don't wanna hurt it
Old Apr 26, 2010 | 03:51 AM
Deezel Stink3r's Avatar
There is a huge thread about 2-stroke oil in the alternative fuel, additives and fluid section.
2- stroke oil burns better than Diesel. Adding it will not harm your engine at all. But it decreases wear.
But have in mind it can't repair or undo any damage that happened already at a mileage 193000 miles.
Read here for all information:
https://www.dieselbombers.com/altern...il-thread.html
Old Apr 26, 2010 | 10:43 AM
CSIPSD's Avatar
2 stroke will not help or hurt anything. Its not worth the cost.
I run Diesel Fuel in my Diesel truck. I have never had a fuel related issue in over a million miles on these trucks running what is suposed to be in the tank...
DIESEL FUEL...
