6.7 cummins ohd question
Old Apr 22, 2010 | 07:34 PM
alk*88's Avatar
Default 6.7 cummins ohd question
my ohd says "perform service". does anyone know what this means. tried clearing it with smarty didnt work. i can turn key on and it says system ok. when i start the truck is when it dings and says "perform service". dont have a clue what it is. thanks in advance for the help.
Old Apr 22, 2010 | 07:37 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
do you still your dpf.
Old Apr 22, 2010 | 07:40 PM
alk*88's Avatar
no dpf is gone
Old Apr 22, 2010 | 07:57 PM
diesel pap's Avatar
are they any codes. mine does that but dont throw a code. i use the smarty and go thru the motions of clearing a code even though they are none there and it always goes away.
Old Apr 22, 2010 | 08:04 PM
BLACK RHINO's Avatar
You can try the oil change reset... Which is turn your key to the on position,Not starting the truck just to the run position. Push the accelerator to the floor three times. Then turn your key off. Will reset it if yours is just doing the change your oil reminder. Works on my 09 anyhow.
Rhino.
Old Apr 22, 2010 | 09:03 PM
alk*88's Avatar
tried using the smarty. went through the steps of eliminating codes. didnt work. it says there are no codes. but tried it anyway. might have to call a shop to see if they can give me a idea what it might be. i also tried the oil change reset. that didnt work either. thought the smarty would clear the code. have to hook it up about every 2000 miles to clear "see dealer know" code.
Old Apr 22, 2010 | 09:12 PM
ETXBlueRam's Avatar
If you want, I'll walk you through resetting your ECM. It's fairly simple.
Old Apr 22, 2010 | 11:09 PM
mikeshauling's Avatar
ccv filter ? how many miles
Old Apr 26, 2010 | 02:08 PM
Lil Dog's Avatar
Could be oil timer for service, air filter service or CCV filter. All will not be displayed on the Smarty..
Old Apr 28, 2010 | 11:33 PM
raptr85's Avatar
i bet you just rolled over 67500 miles on your truck, it automatically comes on for the scheduled maintenance for cleaning the dpf, change the ccv filter, cleaning the EGR.
