2000 ford garret gtp38r turbo boost
Old Apr 22, 2010 | 06:33 PM
stephenjr's Avatar
Default 2000 ford garret gtp38r turbo boost
I have a garret gtp38r turbo i just put on my truck with stage 2 inj. And i have a cheap manual boost controller and i have it all the way shut and my boost guage is only saying 30lbs max. i want 37. Any ideas? I know the turbo can hold it
Old Apr 22, 2010 | 10:49 PM
CSIPSD's Avatar
What happened to the factory wastegate control rod?
Wanting and having are two differant things, boost is not HP, what are your EGT's and how much smoke?
Old Apr 23, 2010 | 07:11 AM
stephenjr's Avatar
What about the waistgate rod? Its still there. I have black smoke when i get on it, and the egts are about 1100 witch isnt to to bad
Old Apr 23, 2010 | 09:48 AM
big_stroker's Avatar
You probably need to adjust the waste gate rod so it will stay closed longer.
your EGT's pre or post turbo?
Old Apr 23, 2010 | 10:08 AM
stephenjr's Avatar
egt probe is drilled into the exh.. manifold right at the motor. How do you adjust the waistgate rod, that makes sence it has threads on it. thank you
Old Apr 23, 2010 | 11:03 AM
CSIPSD's Avatar
You say you have a boost controler here??? What is it? A Map blow off or a regulator? Ajusting that will NOT get you more boost...
Stock injectors thats good.
You have to remove the rod from the wastegate and shorten it. Having compressed air makes it easy to do.
The hardest part is not loosing the C clip that holds the rod to the wastegate.
Old Apr 23, 2010 | 11:12 AM
stephenjr's Avatar
Ijust tryed shorting it a bit i really had to pull on the rod but i still saw no more boost i saw 22-25. my goal is 37. Do i need to make it super short and use the compressed air to make it easyer to hook the rod?
Old Apr 23, 2010 | 11:40 AM
CSIPSD's Avatar
If you can unhook and reconnect the rod without a pair of vice grips then its not tight enough. It should be a REAL pain in the butt to reconnect.
Again, your "goal" and what your injectors are capable of are two differant things, boost does not mean HP.
I can say for sure at 20psi I am making more HP then you are at 37... Get it tightened down a bit more!
Old Apr 24, 2010 | 02:45 PM
stephenjr's Avatar
mission complete the two orange boots on the bottom of the cold side of intake one was half off. but looked on. I got new boots and omg i love it!!! Thanks guys
Old Apr 26, 2010 | 12:34 PM
CoalTrain99's Avatar
run alot of nitrous it will def help the boost out,
avatardvr
18
Aug 8, 2019 12:38 AM
Aug 10, 2015 06:40 PM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
Nov 16, 2014 05:14 AM
