Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
Towed about 10k+ with the Ex yesterday
Old Apr 18, 2010 | 07:25 AM
njneer1's Avatar
Default Towed about 10k+ with the Ex yesterday
Towed an 18ft equipment trailer loaded with landscaping blocks for a buddy yesterday. It was heavy ! I don't recommend towing that heavy with the Ex's stock hitch and stock rear springs for any long distances ......squirrely *** end for sure !.....need to get that rear sway installed. Now I know why Ex guys that tow are using B codes, Firestone air bags and weight distributing hitches ! ..........She pulled fine.....downhill was the squirrely part.
Old Apr 18, 2010 | 03:07 PM
ArizonaRedneck's Avatar
how far did you have to tow it and did you have the pucker power when going down hill
Old Apr 19, 2010 | 06:38 PM
CSIPSD's Avatar
I've pulled about 14k with the wifes excursion more then a few times, but she is lifted 6"...
Old Apr 19, 2010 | 07:47 PM
njneer1's Avatar
yes......about 10 miles....my butt was sucking the leather on the down hill !!!!
No problems ??? you know that Ex is only rated for 10k......
Old Apr 20, 2010 | 12:54 AM
CSIPSD's Avatar
10k 18k... whats a few k's between friends...
It will tow what you want fine once you get some stiffer springs in there. The add a leaf helped a ton!
Old Apr 24, 2010 | 08:16 AM
njneer1's Avatar
What are you running on yours again ??
Old Jul 5, 2010 | 04:05 PM
drewkeen's Avatar
The stock Ex springs are terribly when towing heavy.
Old Jul 5, 2010 | 06:03 PM
tiremann9669's Avatar
What ply are your tires, that can make a big difference too
Old Jul 16, 2010 | 01:19 PM
njneer1's Avatar
I am running Load range D......can't tell any difference from the E's i had before
I think that was the biggest problem....my stock springs
coal_life
Aug 26, 2015 07:50 PM
