2003 Duramax will not start engine is hot without prime.
Old Apr 17, 2010 | 08:17 PM
ArmyDawg's Avatar
Default 2003 Duramax will not start engine is hot without prime.
Having trouble restarting my 2003 Duramax when it has warmed up for 10 minutes or more.
Symptoms:
No codes
Starts cold with in seconds
Runs great
No smoke
No loss of power
No fuel in crankcase oil
Replaced fuel filter with in 100 miles
Replaced fuel filter/primer pump with in 100 miles
Will start when engine is hot after depressing primer pump 4 or 5 times (until firm)
Wife ran truck out of fuel 500 miles ago
Altinator went bad 600 miles ago.
Replaced one battery 450 miles ago
Any Ideas anyone
Old Apr 17, 2010 | 08:21 PM
12vcummins96's Avatar
sounds like a bad cp3
Old Apr 17, 2010 | 08:24 PM
ArmyDawg's Avatar
My ignorance
What is a CP3?
Old Apr 17, 2010 | 08:32 PM
the injector pump
ArmyDawg's Avatar
Thanks for the suggestion.
How do you check out the CP3 Fuel pump regulator?
Engine idles fine
ECM lost VIN after altenator went bad and truck almost shut down when batteries went dead.
Replaced ECM
Old Apr 17, 2010 | 08:33 PM
do you have a rail pressure guage
Old Apr 17, 2010 | 08:37 PM
ArmyDawg's Avatar
Ran the fuel pressure up with the computer.
Pressure did not drop off.
Ned to get one.
the lift pump pressure or cp3 pressure
Old Apr 17, 2010 | 08:53 PM
ArmyDawg's Avatar
Don't know which pressure they were showing me at the GMC shop on the computer.
My curosity is why does the truck start great in the morning when the engine is cold and just crank over when it is hot?
Old Apr 17, 2010 | 09:01 PM
i had a ford idi 7.3 that when it was cold would fire right up then when it got hot it would not start unless i used some kind of starting agent
when your wife ran it out of fuel your injector pump was ran dry no lube means alot of wear real quick and i think that is your issue
