Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
Where's my leak ??
Old Apr 16, 2010 | 09:37 PM
njneer1's Avatar
Default Where's my leak ??
Ok.....leaving oil, on the driveway........looks like the rear main, but I know that's unusual....what's the most likely place ? HPOP ? turbo pedestal or EBV valve ?.....or some where else ??
Old Apr 16, 2010 | 10:25 PM
CSIPSD's Avatar
Check the valley, I would bet its full of oil.
Old Apr 18, 2010 | 07:12 AM
njneer1's Avatar
It is.....where's the most likely place to leak up there ?? what's the best way to tell where it coming from ?? Just clean it out and start looking for the fresh leak ?
Old Apr 18, 2010 | 03:32 PM
scrotom's Avatar
Don't they make a dye to help locate leaks? Good luck buddy
Old Jan 28, 2012 | 02:19 PM
losguy830's Avatar
i am leaking fuel. seen where i should change the o rings on the drain valve. will do. but, there is a pan tha covers the torque converter, is there supposed to be a half moon shaped hole in the pan? i have diesel coming from there as well. could the fuel be the same as the leak from up top at the drain valve leak?
LariatOutlawGirl
Sep 1, 2015 02:15 AM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
