Valve Lash Adjustment
Old Apr 16, 2010 | 07:57 PM
DanS's Avatar
Default Valve Lash Adjustment
Any good write ups on the the 6.7 valve lash adjustment procedure? Is it the same as the 5.9 .010 and .015? Is the process the same?
Old Apr 16, 2010 | 09:36 PM
ArizonaRedneck's Avatar
how to aadjust valve lash on a QSB 6.7 - JustAnswer go here and go to accepted answer and go to click here
Old Jun 17, 2010 | 11:05 AM
ShibbyUTman's Avatar
depending on your equipment level the specs can be varied a bit from what is called out. If you are running stock with EGR and DPF it is best to run with the specs called out in the service manual. If you have the DPF and EGR removed most guys are finding that adjusting the valves to the 5.9 specification makes that annoying off load rattle go away.
RA113024
Mar 13, 2016 07:42 PM
Baradium
Mar 9, 2015 07:15 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
woodsman27
Oct 26, 2014 02:13 AM
